Shutter clicks twice
nilescrane
Posted 21/07/2010 - 15:22 Link
My K-x is set to take single shots, but often when I press the shutter it takes 2 shots. Any ideas? Thanks.
flossie
Posted 21/07/2010 - 15:31 Link
this might be a stupid question, but are you in Live View mode?
nilescrane
Posted 21/07/2010 - 15:47 Link
No- I don't often use Live View.
Mannesty
Posted 21/07/2010 - 16:34 Link
Dodgy shutter button maybe?
BigJacko
Posted 21/07/2010 - 18:57 Link
Hi. First, what mode are you shooting in, as far as the main dial is concerned? This may explain things (some of the SCENE modes automaticaly engage Continuous mode, for example).
Secondly, what does the main LCD display show for the top icon out of the five that make up the 'paw-print' group of icons?
This top icon shows the current 'Drive' mode, and maybe you're in 'Auto Exposure Bracketing' mode which looks a bit like: Comment Image
(but is not exactly the same... the + is on a white background, and there are a couple of 'stacked' square icons behind the main one, to show that it will take multiple shots at different exposure levels).
Alternatively, you might be in 'Continuous Shooting' mode (icon is Comment Image
, but has Hi or Lo in the top-right corner of the icon). Bear in mind though, as I said above, if you're in one of the main dial modes that auto-select this drive mode, you may not be able to switch it off. Just use a different main-dial mode instead!
To narrow down which setting it might be, try this: If you leave your finger on the shutter a long time, does it KEEP taking shots, or does it take just three and then stop? If the former, then you're in Continous mode, I reckon. If the latter, then you're in Auto Exposure Bracket, probably. The reason you were only seeing two shots was probably because you didn't hold the button down long enough for the third shot to fire!
Final thing to check is the photos themselves - if the second one is marked with any kind of positive or negative 'Exposure Compensation' when you view its EXIF file, or its INFO (on-camera via the LCD), then I'd say Auto Exposure Bracketing is the cause. Likewise, the EXIF data will record whether Continous mode was on or off at the time of the shot.
Either way, the solution is simple enough - simply press the corresponding top button in the 'paw-print' on the K-x's back (the one marked Comment Image
and select the first icon - the green square Comment Image
- Single Frame Shooting, and you should be alright. Or change the main dial to use another main mode that doesn't engage this drive mode, as mentioned above.
Hope this helps. Please let me know if it does.
Neil
Pentax K-x ♥ Pentax DA L 18-55mm f3.5-5.6 AL ♣ Pentax DA L 55-300mm f4-5.8 ED ♦ Pentax A 50mm f2.0 ♠ Pentax AF360FGZ flash ♥ Rikenon P 50mm f1.7 ♣ Vivitar CF 28mm f2.8 (K02 Komine) ♦ Tokina 80-200mm f4 ♠ Vivitar MC 2x22 Tele Converter
"Rules are for the obedience of fools and the guidance of wise men" - Douglas 'Tin-Legs' Bader
Daniel Bridge
Posted 21/07/2010 - 19:49 Link
If you want me to have a look, I'll be at Bedfords on Sunday.
Dan
nilescrane
Posted 21/07/2010 - 20:19 Link
Thanks Neil for your exhaustive response . I've just checked and the camera is on aperture mode, and is definitely set for single frame. I tested it and the shutter clicks twice (not more) intermittently, say once every 10 or 20 shots. If there is a fault it's a relief that I bought it from a well-known shop in Watford
Thanks Daniel- I may well take you up on your offer!
Edited by nilescrane: 21/07/2010 - 20:22
BigJacko
Posted 21/07/2010 - 20:49 Link
How strange. Sorry my missive didn't help... but it was worth a stab.
Just out of curiousity, do you actually get two photos recorded, in those times where it clicks twice? If so, are there any differences between the two shots recorded in the EXIFs? Another long shot, but it might shed some light.
Otherwise it does sound like something's gone haywire, doesn't it? Maybe the shutter button itself is not de-bouncing properly - as Mannesty says..."dodgy". Slack return spring? Certainly I'd be hard pushed to imagine an 'electronic' cause, but I suppose it is possible too.
Good luck with finding the solution. Please do let us know what it was, won't you? Just in case it happens to me too! LOL
Neil
myles
Posted 22/07/2010 - 00:20 Link
Assuming you only get one image with your two clicks, what shutter speeds are being recorded?
Just a thought.
Myles
nilescrane
Posted 25/07/2010 - 20:43 Link
I get 2 separate images, as if I'd pressed the shutter twice.
Anyway I got a pro to check the camera over (thanks Mr Bridge ) and he confirmed that the shutter button is faulty.
So I'll be using my new Freedom Pass to travel to Watford for a repair (to the camera, not to me!).
Edited by nilescrane: 25/07/2010 - 20:48
BigJacko
Posted 25/07/2010 - 21:14 Link
Thanks for letting us know, Niles. I shall keep an eye on my shutter button and hope for the best! Good luck with getting yours fixed. Make sure they do it under warranty!
Neil
Daniel Bridge
Posted 25/07/2010 - 23:46 Link
You're welcome Mr. Crane.
Dan
Rowmac
Posted 17/08/2010 - 14:11 Link
I know this is a little irrelevant to the current thread but also, when you have High ISO noise reduction on, the K-x will take two shots at different exposure settings, using the difference to help cancel out noise. (Or so the manual reads)
Pentax K-x, 18-55mm & 50-200mm Kit lenses, Pentax FA 50mm F1.4 Prime "DSLR & Photography for Dummies", Gorillapod SLR-Zoom, Hama Profil Duo II Tripod
Edited by Rowmac: 17/08/2010 - 14:12
pentaxian450
Posted 17/08/2010 - 14:33 Link
The second shot is taken off the sensor with the shutter closed and the mirror in the down position to get a dark frame, so it wouldn't click twice.
Rowmac
Posted 17/08/2010 - 14:45 Link
That's the one! Cheers Pentaxian450
