Shopping for WR lens rant
Posted 03/03/2012 - 21:14 Link
Having spent most of my life with Pentax and most of there Lenses, I considered myself semi-pro in my standard of photography, lenses, exposures, Composition, great, last Pentax a super A, (still have it in excellent condition).
Then children came along + expense.
My first venture into digital was a Fugi 602s and never been truly convinced with digital, so with children grown up and out of the way (or pocket) it has left me able to pursue my love of photography ----( wife permitting ) lol, so now after scrutinising specs for all makes of Camera, still came back to Pentax as camera of choice, + the added fact I can use all my old lenses and filters, so purchased the K5 body only, as above having manual lenses kept costs down.
Now having the K5, local R S photographic lent me the 18 to 135 to try and compare, no comparison really!”!, although all my other lenses work fine with the K5, none compare really with the 18-135 so I researched lenses as to what I require/ or would commonly use and decided on the 18-135 as a starting point as a really good and all round lens which seems to suit most of my needs as now on a learning curve into Digital.
A point being I purchased the K5 with an emphasis on the fact that a lot of what I do with a camera is often in not so nice weather, so the WR factor means a lot to me, (no more waterproof hoods) but I have found several shops now plugging lenses as being far cheaper than Pentax and when queried whether they are WR, the response has been that it’s not really necessary! SO why did I get a WR camera if the lenses need covering in the wet, No! I want WR lenses as well, so annoying that pro shops in a specialised area still try to push cheap!! Cause they get a good deal maybe?
Pentax super A 35mm.
Pentax K5 apsc
Pentax K1Mkii full format.
Pentaxophile
Posted 03/03/2012 - 21:34 Link
Why the rant, if you want a WR lens, just buy one! You have the 18-55WR, 16-50, 55*, 50-135*, 50-200WR, 60-250*, 90WR, 200* and 300* to choose from! Probably your local shops just don't stock them. So order them online.
Posted 03/03/2012 - 21:40 Link
Probably still a bit old fashioned trying to support local businesses, agreed online may be the answer, thanks for the reminder.
Pentax K5 apsc
Mike-P
Posted 03/03/2012 - 22:05 Link
Pentaxophile wrote:
90WR
Presuming you mean the 100mm WR Macro?
Pentaxophile
Posted 04/03/2012 - 00:25 Link
Tamron have poisoned my mind! Sorry for responding to your rant with... another rant, by the way, Rob!
Edited by Pentaxophile: 04/03/2012 - 00:26
jeeess1967
Posted 04/03/2012 - 12:26 Link
Hi Rob,
If you have a WR camera, it is sensible that you have at least one WR lens in your line up. I have a 18-55 WR and an 50-200 WR. Performance-wise both are good, 50-200 being the better among the two. These two are cheaper too when compared to other WR lenses. So why not start with either of these? Good luck.
Regards,
Jeeess
K-5, K-7 and K10D, Pentax 18-135 WR,18-55 WR,Pentax 28-105,Sigma 28-300, Sigma 28-80 (Macro) and Pentax 50-200 WR.
vrapan
Posted 04/03/2012 - 14:24 Link
It is the shame the primes aren't WR lenses... It would make sense for them to be I think as in any case a lot less to go wrong with them in bad weather so it would probably be an easier/cheaper job to do.
In any case I am well covered with the 16-50 and 50-135
rparmar
Posted 04/03/2012 - 16:22 Link
It's far more important to have a WR body, since there are many points of failure. Next most important are zooms, depending on their construction. But a prime only needs a single gasket. I wouldn't worry too much about using a non-WR prime with a WR body, for casual use. So I guess I'm agreeing, in part, with the retailers. (There's a first time for everything!)
Listen to my albums free on BandCamp. Or visit my main website for links to photography, etc.
Edited by rparmar: 04/03/2012 - 16:24
Posted 08/03/2012 - 21:41 Link
thanks for the comments everyone, bought the K5 partly because of its WR benefits, especialy with the type of weather i am out in and always try to have a camera with me, I have now picked up the 18-135 Wr lens as a starter / allrounder lense (very pleased with it to), and looking next at something around the 300mm to 500mm range, still preferably Wr- looking now,I accept the range of WRs is limited so will look closely at some of the primes, for sunny days
I would happily purchase all WR if they were available, from a personal point of view.(shame they are not indestructable as well)
Pentax K5 apsc
