Shallow DOF
Posted 19/05/2009 - 09:37
It has the same DOF as any other lens when set to a particular aperture, but at f1.2 this will indeed be very shallow.
If this version does not have an "A" setting on the aperture ring then your camera will only fire at open aperture, so it will be f1.2 all the time. In this case, you need to set the aperture use (custom menu) as "permitted" and then use the stop down method of metering to make sure the lens stops down when you take the picture.
You can use Av and M modes with this method. If you do a search on the forum you will find lots of threads covering the method in more detail.
Posted 19/05/2009 - 10:50
The two Pentax 50mm 1:1.2 lenses (original K and A) will facilitate capturing an image in very low lighting conditions. The trade-off is shallow DOF and apparent softness.
A couple of stops down and the images will sharpen up considerably and the DOF will improve.
Your image above looks underexposed anyway. What were the lighting conditions?
Posted 19/05/2009 - 19:52
it was taken at 100 asa f2.8 1/60sec in available light which was not all that good , its also quite difficult to determine the focus on the standard screen. will have to experiment to get the best results.
Posted 19/05/2009 - 23:08
hi, the lens reads smc pentax-a 1:2 50mm,
tim.
tim.
Posted 19/05/2009 - 23:12
Tim
That is an f2.0 lens. So about 1 1/2 stops slower than the f1.2. But a very fine lens anyway.
Posted 19/05/2009 - 23:24
peter,thanks have taken a couple of shots at f8 and they are super sharp , but obviously the background isnt as blurred .
tim
tim
Posted 19/05/2009 - 23:40
[IMG]http://i484.photobucket.com/albums/rr203/timritaharry/IMGP1138.jpg[/IMG]
this was taken at f:2 1/80 again a very shallow dof,
Posted 20/05/2009 - 01:02
tim.
As Peter has already said, that lens has a maximum aperture of f2, not f1.2. It's a very common mistake, made mostly when being sold on auction sites and incorrectly described as 1.2 instead of 1:2.hi, the lens reads smc pentax-a 1:2 50mm,
tim.
It was the standard kit lens sold with MF cameras in the later years of that era. Before that the 1:1.7 was the norm.
It's still a good lens though.
Blackburn Lancashire
have just bought a smc 50 1.2 , it seems to have a very shallow depth of field ,one half of the mask is in focus the other not , is this because its made for 35mm? (k200d)
