Shake Reduction with a 2x Teleconverter
robbycuk
Posted 07/06/2008 - 22:45 Link
I've just realised that when I use my K10d with a 2x converter it doesn't read the change in focal length of the lens. I only noticed as one of my lenses didn't register to the camera properly once when using the 2x so I manually set it, but then switched the camera off & then on again & had different lens values in the exif data when I reviewed the photos later.
Big question is - does it affect the efficiency of the shake reduction when it hasn't registered the correct lens? Is there a chance of a tweak in the firmware to allow us to control the lens if we are adding a tele or extension tubes (I assume these would generate the same problem)?
Rob
Bodies: K10d, P30, SFX
Lenses: Lots
iceblinker
Posted 08/06/2008 - 00:39 Link
Yes. SR behaves differently according to what focal length it thinks the lens is. Whether SR is still worth using when incorrectly set, or whether it's worse than useless, I'm not sure.
This would be very easy for Pentax to program, but unfortuantely there seems no sign or hope from anyone that there will ever be another firmware update for the K10D
~Pete
