Settings help
Posted 28/07/2014 - 20:55
The K3 has an inbuilt HDR mode doesn't it?
The lower settings on this mode are usually pretty good, with no over the top HDR effects.
A tripod is still recommended for best results.
Posted 28/07/2014 - 22:32
johnriley wrote:
Fill-in flash is one way and it will be more realistic if the interior is allowed to remain quite dark compared to the exterior. The flash exposure can be balanced and it will work with the built in flash.
That's what I would do - took quite a lot of shots in bunkers in Normandy last year and they mostly came out ok . All depends on how big the bunker is - the one in the OP's photo isn't that big so should not be a problem. The difference in the outside meter reading and inside will be large so not easy to do hdr that looks natural.
Posted 29/07/2014 - 10:43
I would go this way too
Posted 29/07/2014 - 11:43
As I said before and now Ken seems to agree go for flash. Best would be a full flashgun on the top with a "Stofen" diffuser or similar.
CHEERS Vic
PS. if you have an old semi clear (white) 35mm film container cut a slot lengthwise in it to fit over your popup flash and this makes a nice little all round deffuser. Vic
CHEERS Vic
Posted 16/09/2014 - 10:58
Though the two shot and photoshop route. Still makes me feel like im cheating....lol
____________________
fut 15 coins
fut 15 coins
Posted 16/09/2014 - 12:10
Trying to imagine this from the inside. I think deep shadows would be normal and even desirable to emphasise in places.
In a rush I would try HDR or double exposure route with very careful and subtle bringing-up of dark areas back home in post. The K5 would certainly be able to do this with just one raw shot, not sure about the K3 tho as I don't have one. I can't imagine the pop-up flash working - at least not without lots of help to create depth and interest, in which case...
with more time, I would take an off-camera flash and try firing it in from the outside, creating lovely shadows and textures. You could take multiple exposures moving the flash and knit them together to make better use of it. Maybe even add some smoke or dust (subtle, not cheesy).
Footnote: I routinely take bracketed shots and routinely only use one of them when I discover the K5 has all the info I need
stroud,glos
