Servicing/Cleaning for Pentax film cameras
Posted 23/09/2021 - 12:53 - Helpful Comment
Hello Andy.
Robin at Harrow Technical ( https://harrowtechnical.co.uk/ ) is able to repair and service film cameras. High quality work and excellent customer service. Recommended by me as a happy customer.
Robin semi-retired a couple of years ago and now runs the business from home. This means he has a more limited capacity for new work and there is a note on the front page of his website stating he is currently not accepting new items for repair due to "volumes". If you're not in a hurry, it may be worth contacting Robin to see if he has an idea as to when he'll be able to accept new work.
Nigel.
Posted 24/09/2021 - 19:20
Posted 01/10/2021 - 12:46
Thanks for the input guys, ill give one of them a go...
A few bits & Bobs
Posted 01/10/2021 - 13:03
With the ME Super the mirror is stuck up, id not seen this in my years of ownership of these....is it a known issue?
Other than that the camera is pretty much mint.....
Will probably have a couple of vivitar lenses for sale in the near future.....
A few bits & Bobs
Posted 01/10/2021 - 17:06
The mirrors can lock up if the battery power fails, but otherwise most of the problems with ME series cameras that I have known have been electronic or film transport. They are very old now.....
Posted 01/10/2021 - 23:10
Sometimes the mirror foam gets sticky and holds the mirror up.
Posted 03/10/2021 - 10:40 - Helpful Comment
The ME's suffer badly from sitting and not being used. There are components in the mechanism that degrade over time and cause the film winding to lock up. It doesn't sound as if yours has this particular issue, it sounds more like sticky foam causing the mirror not to return, but it could also be sticky lubricant on the mirror pivot points. The foam is an easy fix if it is the only problem, just buy some sticky backed foam from ebay, 2mm or 3mm, then cut a strip to fit. To clean away the old residue you will need some isopropyl alcohol and some toothpicks or similar. Make sure you don't get any of the old foam on the prism.
Kind Regards
Kind Regards
Posted 04/10/2021 - 10:51
Ive decided to treat both bodies to a good service....
I also need to get my 50-135 off for a new SDM motor
A few bits & Bobs
Posted 23/05/2022 - 20:41
Resurrecting an old thread.
Andy - who did you go with in the end? I have a nice black MX that needs some work.
Many thanks
Many thanks
Posted 01/03/2023 - 09:18
Many thanks
Many thanks
A few bits & Bobs
Posted 01/03/2023 - 09:21
So sorry I’ve literally just seen this comment…oops
I went with Asahiphoto in Harrow, he’s done 4 camera bodies for me now.. well pleased with the results!
MX x 2, ME Super & a Super A an MV1 & a LX to go
A few bits & Bobs
12 years
Cambridge,
UK
Have recently acquired an MX and now a Black ME Super....
