Sensor Dust - Zeelon Anti-Static Blower
Posted 11/11/2009 - 16:27
Use the Pentax kit, the blowers can cause more problems than they solve. There is a video on youtube demonstrating its use.
By the way, someone at Pentax has a sense of humour as the part number for the kit is O-ICK1
K.
K.
Posted 11/11/2009 - 16:42
There is no need for any trepidation, you aren't even going to touch the sensor itself but a piece of glass in front of it. Just make sure the battery is fully charged and follow the cleaing kit's instructions, you will be fine. The blower reviewed in AP wont be any more powerful than any other one of a similar size.
I once had sensor dust but since using a Giottos Rocket occasionally and an Eclipse cleaning set twice (in five years) all has been well.
Posted 12/11/2009 - 12:56
i have been using the pentax sensor claening system for the past 20 months and its still working fine - its a good piece of kit, easy to use and does a good job. just remember not to put much pressure on the sensor and you will be fine - the youtube video is a good one to watch
K7D DA 18-55 mk11WR|50-200 wr|DA16-45|Tamron SP90|lots of manual pentax glass
Posted 12/11/2009 - 16:34
Many thanks for your advice, everyone. I have also watched the Youtube video which, along with your help, has given me enough confidence to tackle the job.
John
John
Posted 12/11/2009 - 19:24
I have experienced sensor cleaning in other ways. After stupidly changing lenses in dusty cambodia my sensor got literally smothered with dust and grime. I too got scarrrrreeeeeeddd. After some advice I bought a rocket blower off ebay for next to nothing. I soon discovered a little technique that simply cannot fail: mount your K10 on your tripod with the lens facing down to the ground, remove your lense slowly, open up the sensor, and from underneath carefully insert the rocker blower into the camera a good cm distance from the sensor......then blow like mad. This way having your mount facing down all dust that is blown off the sensor and around is blown out of the camera not around other areas of the camera waiting to stick back onto the sensor the next time its open. This method might seem a bit odd, but I can tell you, for me all that dust from cambodia disappeared in a second. I disagree with other comments made. Cleaning a sensor with chemicals is far more risky the a simple blower
Kent
I bought a Pentax digital SLR sensor cleaning kit two years ago but have never needed it until now.
I am a complete novice when it comes to sensor cleaning and it scares me to death!
Is a blower better (safer) than the cleaning kit? Has anyone tried the one above?
Would I be better off using the Pentax kit even though it it two years old?
Thanks,
John
