Sekonic L308s
Posted 30/07/2014 - 21:07
Is the 308s compatible with the lights your trying to trigger ? I always trigger mine manually.
Chris
Posted 30/07/2014 - 21:24
The L-308s cannot fire a strobe light. unless you connect a sync cable between the two.
Stuart..
Stuart..
Posted 30/07/2014 - 22:45
Hi with my KR it doesent have a symc opening is their some other way round it, if strobe triggerd manually will it give me readingThe L-308s cannot fire a strobe light. unless you connect a sync cable between the two.
Thanks for the help
Posted 30/07/2014 - 23:13
The sync cable is used between the meter and the strobe light. If the strobe is triggered manually you will get a reading. I have the L-308/s its a good meter. I find the easiest way to use it. Is to use a wireless trigger. With the receiver connected to the strobes. Just keep the trigger in hand as you meter. Or better still get a second trigger. you con get a complete set of triggers and receivers for under a tenner on ebay..
Stuart..
Stuart..
Posted 31/07/2014 - 07:33
Cheers mate will check it out today, I would have thought that I could have got a flash reading with it as I tried it with my flash gun sat on cameraThe sync cable is used between the meter and the strobe light. If the strobe is triggered manually you will get a reading. I have the L-308/s its a good meter. I find the easiest way to use it. Is to use a wireless trigger. With the receiver connected to the strobes. Just keep the trigger in hand as you meter. Or better still get a second trigger. you con get a complete set of triggers and receivers for under a tenner on ebay..
Regards Dave
Posted 31/07/2014 - 10:08
If your using on camera flash. Then its either a two person job. Or you can prop the meter up against your subject. The second on isn't especially great but you will get a reading. Interested how you get on.
Stuart..
Stuart..
Posted 31/07/2014 - 13:33
When you see this flashmate on youtube it seems to work as good as the other sekonics on the market, when geting a flash reading off strobe or flash gun does the mode still have to be in triggerd flash mode or unless using sync cable
Regards Dave
Regards Dave
Posted 31/07/2014 - 16:34
Hi,thanks for your help tryed flashmate with sync cable to strobe and got a reading also with trigger and the reading was the same then tryed it with the flash and got a reading, i am one happy bunny lol. I was thinking i got sold a dud flashmate
thank you.
thank you.
Posted 31/07/2014 - 17:49
Glad you got it sorted out. Its a very accurate meter.
Stuart..
Stuart..
Regards Dave
