SDM lens & camera's focusing switch
Posted 15/11/2016 - 15:26 Link
This might seem like a daft question to some, but can anyone advise me, with regard to using a SDM lens……..
When the focus selector switch on the lens is switched to AF, what position should be selected on the camera’s focus selection switch?
I have a Pentax K30 with AF.S/C/MF settings, I don’t yet own a SDM lens, but I am considering one.
JAK
Posted 15/11/2016 - 15:41 Link
For auto focus both switches need to be on AF. If either or both are on MF that's what you'll get.
If you use back button focussing rather than the shutter release focussing you get the best of both worlds. The lens will focus when you press the rear AF button, but will not try again when you press the shutter release so you don't have to wait while it tries to focus yet again. Might not be ideal for every subject but often works the best, though might need a bit of getting used to.
I've been trying to think of any instances where back button focussing may not be ideal. I'm still thinking... nothing's come to mind so far!
Edited by JAK: 15/11/2016 - 15:47
redbusa99
Posted 15/11/2016 - 16:14 Link
just note when you disable shutter release focus it disables CIF as well, should you wish to use it shutter release focus has to be enabled. found that out after thinking it had gone wrong when i switched to back button focus
odd lens or 2
Posted 15/11/2016 - 17:15 Link
Thanks for the advice....much appreciated.
Posted 15/11/2016 - 17:22 Link
Thanks for the info...much appreciated
JAK
Posted 15/11/2016 - 17:24 Link
Pleasure. Note your user name, why are you an unhappy snapper? Or has that changed since getting a Pentax?
Edited by JAK: 15/11/2016 - 17:24
Posted 15/11/2016 - 17:39 Link
I joined the forum as I had the dreaded aperture motor failure on my K30 (now resolved).
At the time I was very unhappy, but now I'm a bit happier !!
It was a play on the term "happy snaps"
JAK
Posted 15/11/2016 - 18:01 Link
Pleased your K30 is sorted and happier now!
Posted 15/11/2016 - 18:21 Link
Seems OK now, fingers crossed
gfurm
Posted 16/11/2016 - 08:23 Link
In fact that's not true. Put camera or lens in MF, press and hold back af button, press shutter release. CIF works, at least on my K3 II.
Greg
Pentax K-3 II, DA 50/1.8, Sigma 18-35/1.8, DA* 300/4, 1.4x HD DA Converter
