sd viewer
pink
Posted 21/06/2010 - 08:35 Link
Good morning hope you all had a good fathers day
I would like to use a old monitor as a image viewer(in reception) but have no idea how or what hard where to use.
I don't really want to use a old computer or a laptop to power the slide show.
So what are my other options must be small in size.
James
My Fluidr
bwlchmawr
Posted 21/06/2010 - 08:42 Link
James
Driving to mother-in-law's for lunch and passing a huge sign, only son says, "Oh, is it Fathers' Day? Sorry."
Doesn't help you with your question, James, but I had to tell somebody!
Best wishes,
Robert Adams
Ernst Hass
pink
Posted 21/06/2010 - 08:56 Link
haa haa
Thank you Andrew
But there is got to be some one out there with a answer to the question....? It's driving me crazy I have a picture view on a small 7.5" photo frame but not really eye catching is it.
James
My Fluidr
Posted 21/06/2010 - 09:12 Link
No, but you need something with a video output. Like a laptop....and you don't want the alternative to cost as much as a laptop I presume.
How about a refurbished laptop from a local IT shop. It might only cost £150 or £200 to get a really good one.
bforbes
Posted 21/06/2010 - 09:13 Link
If the images are on a disc, would a CD/DVD player link up to the monitor?
Posted 21/06/2010 - 09:26 Link
There are devices like this available. However, they are generally HDMI output.
There may be a VGA output device somewhere...
...if I turn anything up then I'll post a link
thoughton
Posted 21/06/2010 - 09:31 Link
I'll second the DVD player option, I have a cheapo 10" Goodmans one for the car which has an SD slot and video out. The slideshow transitions look a bit ropey though
Tim
FlickrFluidrPPGStreetPortfolio site
bforbes
Posted 21/06/2010 - 09:38 Link
There is a HDMI to VGA socket adapter. I use one from the video card on my computer. It enables me to run two VGA monitors from the same card. .....or am I on the wrong track?link
Edited by bforbes: 21/06/2010 - 09:45
pink
Posted 21/06/2010 - 09:45 Link
Thank you
I have found one on ebay and yes Barrie their is a HDMI to VGA so it look's like I'm sorted just looked at a dvd player but no VGA port.
James
My Fluidr
Posted 21/06/2010 - 11:13 Link
Watch out!!
I believe the HDMI-to-VGA cables are for taking VGA output and connecting to an HDMI TV
You'd want the other way around: to take an HDMI output and drive into a VGA monitor. If you can find this then it'll work with DVD player as well.
Some Google'd threads:
http://www.diynot.com/forums/viewtopic.php?t=13680
Another thread mentioned using an Xbox 360 with a VGA cable to play DVDs...
aliengrove
Posted 21/06/2010 - 11:45 Link
I use one of these link at home for my music connected through the stereo. It also has VGA outputs or you can use a SCART adaptor so it will work on any monitor or TV and has a slideshow function in the picture viewer which I use for going through my pictures on the TV. It's got 4GB of memory (you can get up to 160GB memory versions, mine has 40 GB) or you can get an adaptor to put SD cards in it, although it seems this version takes SD cards anyway.
They go pretty cheaply on ebay which is why I posted that link.
Edited by aliengrove: 21/06/2010 - 11:48
terje-l
Posted 21/06/2010 - 12:11 Link
But newer monitors do have both HDMI and the new DisplayPort inputs...
Terry
Posted 21/06/2010 - 12:15 Link
...and then there's DVI as well
bforbes
Posted 21/06/2010 - 12:17 Link
Is HDMI and DVI not the same? (Here comes Stefan)
Edited by bforbes: 21/06/2010 - 12:19
terje-l
Posted 21/06/2010 - 12:24 Link
HDMI and DVI-I are maybe the same electrically, but they are different plugs physically (as is DisplayPort, the new standard for graphic cards).
Terry
