SD Memory cards
Posted 18/10/2012 - 22:58
Is the 133x card possibly a higher class rating? I've got myself a couple of Pretec Class 16's rated at 567x, but I've found that it's only when the cards are used in a 3.0 usb card slot that you truly notice a difference in the R/W speed.
Possibly the reason vor the price variance is demand in the marketplace.
Posted 18/10/2012 - 23:11
Nope - they are both Class 10s
To me the new nomenclature of UHS-1 is the puzzle - I've been buying Lexar Pros Class 10 with 133X speed more or less since I got my K-x
let the education continue
Posted 18/10/2012 - 23:31
UHS is just an acromyn for Ultra-High Speed, and I believe it's measuring quicker read/write speeds in nanoseconds. If you are uploading perhaps 100 photos, you wont notice anything, but if you were uploading into the 1,000's, you'd begin to see a difference.
Posted 19/10/2012 - 08:06
Posted 19/10/2012 - 08:54
In other words -- just go ahead and buy some ?
Posted 19/10/2012 - 09:46
Yes the K-x has taken the new SDXC cards since v1.02
and the one you are buying is still the earlier SDHC
so there shouldn't be a problem with any of them.
http://www.pentax.jp/english/support/digital/k-x_s.html
Posted 19/10/2012 - 10:08
Ta - time for a Firmware update - and this I do find stressful as things like
After formatting the SD/SDHC card, copy the fwdc206b.bin file to the route directory of the SD/SDHC card.
mean absolutely nothing to me
Posted 19/10/2012 - 10:20
I just copy it and ignore technical babble. Works for me
Posted 19/10/2012 - 10:27
You won't notice any difference un write speed on your camera you will notice a difference when uploading to your computer, will however need a usb 3 card reader and usb 3 computer to take advantage if these speeds.
Concert photography
Concert photography
Posted 19/10/2012 - 10:36
Well as I understand it USB is backward compatible - I'm USB 2 [ Macbook Pro ]
So the card will make no difference to me BUT it's clear that SDHC Cards are being discontinued [ getting very hard to find the smaller cards and for some reason they are now more expensive than the newer SDHC UHS-1 ]
OK will order up 2 of the new variety 8GB cards
Next daft question
Can I use one of the new cards for the Firmware update as I have no blank SDHC cards at present [ which is why I'm needing new cards ] ?
Next daft question
Posted 19/10/2012 - 13:11
With computer gear there's no point in buying last years models.
If you have say a 500GB hard drive and want another you buy
something bigger and faster.
You may have to wait for a faster camera or computer to see
any speed benefit from the latest card but at least you have
the latest rather than something that won't work or will be
slow with new equipment.
I would think the new cards would work OK because they are
SDHC not SDXC which would need the upgraded firmware.
If the worse comes to the worst and the camera can't read
them you could buy a 2GB card just for the firmware for
about £4. Most stores should have then for that price or
7 Day on ebay... link
Glasgow
OK - I like Lexar and refuse to get anything lower than Class 10 cards now.
BUT have hit a wee snag - which I'm hoping that the genii on here can help with.
What's the difference between these two varieties
8GB Lexar Professional SDHC UHS-1 400XSpeed
and
8GB Lexar Professional SDHC 133X Speed.
the 133Xspeed Card is a good bit more expensive than the 400Xspeed Card
I'm puzzled
