SD card slot problems- card won't eject
Posted 30/07/2012 - 15:52 - Helpful Comment
I have that problem with my K5. I have to use tweezers sometimes to get it out.
Try rubbing the edge of the card with fine glass paper. That has cured mine
I think the width of SD cards are getting a bit on the snug side + the K5 has an awkward door (well for someone with fingers like popeye)
regards
Bernard
regards
Bernard
Posted 30/07/2012 - 15:56
It is a tight fit to get the card out. The diminutive Q has a much better spaced door and I hope the next model will keep that improvement.
Posted 30/07/2012 - 16:06
I agree, card in no problem with the K5, however a tighter fit when trying to take out. The slot is quite tight to the card edges, especially as Frog says if you have big fingers.
Paul
Paul
K5's (2)both gripped, K10d gripped, Pentax 28-90 f3.5, Sigma 18-250mm, Sigma 150-500mm. Sigma 105mm f/2.8 EX DG Macro, Sigma 10-20 f.4-5.6.EX DC, Hoya 135 f2.8, Take on 28mm f2.8 Pentax AF360 flash, 2 fill in slaves. 30 metre remote release, Rt angle viewfinder, Giotto NOT 3261B Tripod with Manfrotto 808Rd4 ball head, Manfroto 4861RC2 monopoly, shoulder stock, various filters etc, Panasonic SET HBS HD Video cam, Tamrac Explorer 8x backpack and a sore back.....
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index
https://www.flickr.com/photos/pg20
Paul
:wink
Posted 03/09/2012 - 14:47
regards
Bernard
I'll have to try the fine glass paper option. The tweezers didnt' work.
regards
Bernard
Posted 03/09/2012 - 18:16
Sounds like the popper outer pusher piston is
malfunctioning!
malfunctioning!
Posted 04/09/2012 - 13:33
How often do you need to take the card out?. could you solve the problem by getting a large capacity card or is it better to use a card reader ? .. jeff...
Posted 12/09/2012 - 19:06
Or use a micro SD card in an adapter. might be easier to get the micri sd card out.
I have a Pentax K-7 with SD card slot problems.
At first a card wouldn't pop out properly.
I'd push it in (& expect it to pop out) and it'd pop 1/2 out.
I'd push it in again and after a few pushes it'd pop out.
today putting a card in it didn't stay in.
I pushed (not forced) it in again & it stayed in.
Now it won't come out....I haven't tried a lot to get it out yet.
I'm guessing a spring is broken?
cheers,
Pa.
Pa
