Screw in circular ND Filters
Posted 21/05/2011 - 22:26
Just a suggestion but if you want a screw-in ND why not look for a vari-ND?
http://www.lightcraftworkshop.com/site/page1000.html
Posted 22/05/2011 - 12:17
Hi
I use Cokin P series on most lenses but can not be bothered attaching all that kit to my little 50mm prime - so use circular screw in B+W ND4 and ND8 on this lens - they are not cheap but have always performed well.
What to avoid? Same as always - filters at a price too good to be true
Carl
Carl
Posted 22/05/2011 - 12:41
"What to avoid? Same as always - filters at a price too good to be true"
Good advice...
http://www.hiltonphoto.co.uk/products/bw_filters_1.html
Good advice...
Cheers Jules...
Posted 23/05/2011 - 19:42
There are always the Tiffen ones - wide range and fairly good quality (plastic lens, but OK. They may shatter under impact, but they don't break - have one to prove it when the GX10 fell after the strap failed!
See here: http://www.tiffen.com/
OTOH, I quite like the idea of the variable ones!
Posted 23/05/2011 - 19:46
I've plumped for a set of hitech filters as Teamwork photo & Digital have a offer on for 3 x Grad filters and 3 x ND filters ( both slot in type) for £100 + vat. do like the idea of the fader one though as well.
PPGlink
Pentax K-5 with 18-50mm & 50-200mm Kit Lenses, Pentax 55mm f1.4 SMC DA* SDM Lens, Pentax DA 12-24mm , Pentax DA 35mm macro, Pentax SMC FA 77mm Limited, Pentax SMC FA 43mm Ltd, Pentax SMC F 50mm, Sigma 24-70mm, Metz 58 af-2
Has anyone got any experience with the screw in filters rather than the square slot in type. Any recommendations and things to avoid?
