Santa has failed me!!
Posted 26/12/2008 - 13:24
I think I understand what the manual is telling me but my dotage leaves me uncertain. Do I understand that the 1.4 short is suitable for lens less than 300mm and would therefore suit my purpose? regards Ronald.
Posted 26/12/2008 - 14:09
The manual lists the lenses that are unsuitable for use with the 1.4X-S and 1.4X-L teleconverters. I haven't digested it thouroughly but there are some wide angle lenses that are also unsuitable for use with this T/C.
My recommendation is to look out for a SMC Pentax-F 1.7X AF teleconverter. It has the advantage of turning MF lenses into AF. The image quality is exceptionally good too.
Posted 26/12/2008 - 14:23
Thanks again, Peter. I have not come up against the 1.7 or, it has not registered. If it is the right move then it is worth waiting for. I mostly use the lens mentioned plus my 100mm macro. regards Ronald.
Posted 26/12/2008 - 18:40
I've chased all afternoon for details of the 1.7. I'm told in some forums that they cost an arm and two legs. I'm disabled with only a leg and a half...so I guess that's not on. I am told that they are best for long prime lens and then only at their short end. I am beginning to wonder if I am going down the right route. I have a prime 200mm lens plus I have a 50-200mm zoom that I would like to extend their range, plus a 100mm macro that is only one to two ratio. I was hoping the extender would up this to one to one. Maybe a set of extension tubes and a 100mm =300mm zoom is what I need to aim for. Ronald.
Posted 26/12/2008 - 19:19
I have just bought a 1.7x AF converter from a gentleman on this blog!...pristine condition, haven't managed a day out with it yet but a quick fiddle with it indoors shows great potential.......cant wait to give it a good run out!............Ken
Posted 26/12/2008 - 20:48
Ken,
I read somewhere that there could be a problem of the rear element of the lens coming in contact with the front element of the converter if the rear element of the lens projects beyond the mounting flange.I am not trying to put a damper on your new purchase but I checked mine as soon as I read about the problem.I have used mine with the 50mm f1.7 F & FA and Tamron 90mm & 135 mm f2.5s......John
Posted 26/12/2008 - 21:25
Hi John!....I've read the same,but I did a quick check on my lenses and they are all fine.....the picture quality doen't seem to be effected to any great extent so I'm getting rather excited!,,,,,,,,Ken
Posted 26/12/2008 - 21:30
Hi Ken and Doik. I came up against many warnings about the 1.7 in various forums that I was left unsure exactly how this converter would work with my lens. It's an expensive mistake if they do not work. My macro and my 200mm prime would not present a problem but my zooms certainly would potentially cause an issue. I would be grateful for anything you can guide me on from your experience. Ronald.
Posted 27/12/2008 - 13:18
Come on Ken get your finger out and give it a try. when I had it and had a use for it it worked a treat and I loved it. I'm just glad it's gone to a good home. Lets see some Pic's. CHEERS Vic
isle of wight
