Samsung lenses
ikillrocknroll
Posted 29/03/2008 - 11:54 Link
The samsung lenses are "designed by Schneider"
Does that therefore mean that the pentax versions of the same lens are too?
Posted 29/03/2008 - 14:50 Link
Who are you quoting?
The Samsung lenses are rebadged Pentax lenses but in a Schneider livery.
Who knows who makes what, expcept to say that some of the designs are in conjunction with Tokina and also Tamron.
Pentax have two Vietnam factories manufacturing the lenses, although others are still made in Japan. My 50mm f1.4 is still maked Japan, for example.
dev_tt
Posted 29/03/2008 - 23:07 Link
as far as i know, it is only branding with schneider
Hythloday
Posted 30/03/2008 - 14:51 Link
Pentax makes lenses marketed under two names:
1. Pentax
2. Schneider Kreuznach
All lenses are assembled in Vietnam, also the ones with the Schneider Kreuznach label on them, as I have seen on the Schneider 18-55mm.
The question is whether Pentax designs its own lenses. The following interview gives reasons to believe that Pentax lenses are designed by Schneider Kreuznach. The interview is in German and the translation is made by Babelfish which is quite bad at times:
In as far one can actually still trust Schneider-Kreuznach after (good) the name, as far as it concerns Schneider-Kreuznach lenses into digital cameras from Kodak and Samsung? The short answer reads: "Schneider-Kreuznach is on it only , where also Schneider is in it", the detailed answer gives Peter Lebeda, Leiter Public relation/Communication with Schneider-Kreuznach after, in an interview with photoscala:
What at the Schneider-Kreuznach lenses in the digital cameras of Samsung and Kodak is actual Schneider-Kreuznach, which of it pure marketing with the good name?
Schneider-Kreuznach together the camera concept develops with Samsung and/or Kodak. In the concrete conversion phase is responsible Schneider-Kreuznach for the development of the lenses. It applies thus the principle: "Schneider-Kreuznach is on it only , where also Schneider in it is". The name Schneider-Kreuznach stands for quality. It guaranteed as quality seal with the digital cameras of Samsung and Kodak those world-wide well-known Schneider-Kreuznach quality. Concerns a co-operation in the actual sense of the word, put on as co-operation of two partners - and evenly not around buying a lizence from Schneider-Kreuznach after to the enterprises of the photo and/or electronics industry.
To what extent can one trust in the quality of Schneider-Kreuznach lenses?
The development and the tests with self-developed measuring technique correspond to the high quality criteria, Schneider-Kreuznach also within the professional High end range put on and are on the at present most modern state of the art.
Are the two new Samsung lenses to the DSLR models of Samsung own developments of Schneider-Kreuznach? And/or from where does the remarkable similarity come to the appropriate Pentax lenses?
All of the partners used Schneider-Kreuznach lenses are "Schneider-Kreuznach lenses". The camera concept gives the Design of the camera and concomitantly the Schneider-Kreuznach lenses. I.e. a Schneider-Kreuznach lens in a Samsung camera looks differently than e.g. a Schneider-Kreuznach objective in a Kodak or a roll egg camera. In the concrete case of the change objectives to the DSLR models of Samsung series production runs under Samsung direction. Schneider-Kreuznach is responsible for the development of the lenses, the tests of the prototypes and examining the objectives from series production. The interview led Thomas Maschke for photoscala. We thank the Jos. Schneider optical works GmbH, in the special one our interview partner Peter Lebeda, for the answer of the questions.
http://www.photoscala.de/node/1730
Daniel Bridge
Posted 30/03/2008 - 20:42 Link
This discussion has been had once or twice before, and I think this interview quoted. However, I would suggest the fact that many of the 'Schneider' lenses were available as Pentax ones long before the Samsung ones were available would suggest they are indeed Pentax designs.
Dan
Posted 30/03/2008 - 20:51 Link
Yes, the quotes on the subject from Samsung tend to be very carefully worded and don't actually make any claims about the lenses being Schneider design or manufacture.
