Samsung GX10 body
Posted 12/08/2014 - 14:45
Going to post up photos up tonight ,just thought i'd mention, if anyone was interested in trading for a 50mm A f1.7 ? ...
Sean
Sean
Sean
Sean
Posted 12/08/2014 - 18:07
Has it been firmware updated to v1.30?
Posted 12/08/2014 - 18:23
Hi,no it hasn't ,i did download it it but i couldn't figure out the bin files (not very computer savy )Has it been firmware updated to v1.30?
Sean
Sean
Sean
Posted 12/08/2014 - 19:06
melness wrote:
Sean
Hi,no it hasn't ,i did download it it but i couldn't figure out the bin files (not very computer savy) Has it been firmware updated to v1.30?
Sean
Format the memory card in-camera so there are no other files on it and copy the .BIN file from the downloaded ZIP file onto it either via a card reader, your laptop SD card slot (if you have one) or via the USB cable to the laptop so the camera becomes an external drive. Follow the instructions either on the website or the .PDF file that came with it in the ZIP file. Also ensure your camera battery is fully charged up before you start. It's very simple to do, but if you're not confident doing it yourself, I'm sure the buyer will be able to do it themselves. BTW, is the price inclusive (or not) of UK postage and also there's no mention of what payment method(s) you accept (handy for any prospective buyer to know).
Samsung's summary of the v1.30 firmware update is:
1) A built-in flash function in wireless mode has been added.
2) A function that shifts the AF point from “SELECT” to the centre has been added.
3) A function for changing the ISO setting using the e-dials in Tv/Av modes has been added.
4) A function that can change the ISO sensitivity displayed on the upper LCD panel by using the front e-dial has been added.
5) The green button function available in M mode has been added to Tv/Av modes.
6) A function for switching the Av/Tv settings between the front and rear e-dials has been added.
7) A function that sets the strobe light compensation to its default value, using the green button has been added.
A function that displays the memory size when a memory card is formatted has been added.
9) An improvement in accuracy of controlling exposure when using an external flash.
10) A compatibility with SDM lens (Called Ultrasonic Lens) made in PENTAX has been added.
Seems it's more like the K10D after the update bearing in mind the firmware was released in 2007.
Auldearn..Nairn,
Bonnie Scotland
£70
Will upload photos later
Sean
