Safe to use?
Posted 09/08/2011 - 13:29
The trigger voltage needs to be measured to be sure. Replacing the camera electronics will outweigh what you saved on a flashgun!
Posted 09/08/2011 - 14:22
If you are happy to go with someone elses reported reading the D650 looks OK here: http://www.botzilla.com/photo/strobeVolts.html. Shame the site does not list several of my old flashes from film days.
Pentax KF, K-x, 18-55 DAL, 18-250 DA, 50-300 DA, Tamron 10-24 Di II, Pentax DA 40 XS, DA 15, 21 & 35 Ltds, Sigma 170-500 APO, A 50 F2.0, Vivitar PKA 2x converter, Jessops PKA extension tubes. Samsung GX-10, 18-55.
Pentax Q, Q7 + 01 + 02 + 03 + 06, Pentax 110 Super, 50 + 70mm, Soligor 1.7x TC, 110 to Q adapter, Schneider-Kreuznach Tele-Xenar f4.0 150mm, C mount to Q adapter.
Pentax ME Super, MG, K1000, Cosina CS-1 (+auto attachment).
Various PK lenses.
Various PK lenses.
Posted 09/08/2011 - 14:43
Just switch on and put a digital voltmeter across the contacts.
Posted 09/08/2011 - 14:48
Can I safely use this again
Yes you can - no damage will be done to the flash and it will still work.Can I safely use this again
Your camera may not, but you didn't ask that
Seriously - if the trigger voltage is greater than 8V be wary and take extra advise (or use someone elses camera to check first)
Bernard
Posted 09/08/2011 - 15:02
Well the list is useful for what it has told me as I don't have a digital meter - only an analogue one.
At least I know that the Pentax AF160 and Centon MR20 Ringflash are OK and that Hanimex Pro 550 is not. I will just have to get a slave unit for my other old flashes as the K-x does not have a sync port anyway.
Various PK lenses.
Various PK lenses.
Posted 09/08/2011 - 15:05
Any voltmeter should work (I would think) as long as it
has a range going up to about 600V which would cover most
smaller flashes.
An alternative is use an old ballpoint pen to short
out the PC lead. If it welds the ball in the pen to the
outer brass.... stay clear!
smaller flashes.
Posted 09/08/2011 - 17:07
Thanks to all of you for the advice.
I'll test it with a voltmeter as soon as I can get access, just to be safe.
Dave.
Dave.
Posted 10/08/2011 - 10:53
It works fine, I use one on my K-5 as the Voltage is less than 5v.
Paid £12.00 for it and its a great flash for strobist work.
Pentax k-5
Metz 50 AF-1
Pentax SMC 50mm 1.4
Sigma 70mm 2.8 MACRO
Sigma 17mm-70mm F2.8 - 4
Pentax 18mm-55mm f3.5-56 DA WR
Pentax 50mm-200mm f3.5-5.6 DA WR
Metz 50 AF-1
Pentax SMC 50mm 1.4
Posted 10/08/2011 - 11:49
Analogue meter will be fine.Well the list is useful for what it has told me as I don't have a digital meter - only an analogue one.
Providing it has a high ohms per volt spec. Which most have in the higher voltage range.
Take care.
Chris R.
Chris R.
I. El. (Eng). (Rtd).
Posted 10/08/2011 - 15:07
Thanks Chris - I will have to dig out my meter and check the spec.
Various PK lenses.
Various PK lenses.
Posted 15/08/2011 - 12:16
Eventually got around to testing with a voltmeter and got a reading of 3.7 v. So if anyone else, like me, discovers a long forgotten LCD632, they are safe to use.
Dave.
Dave.
Posted 15/08/2011 - 13:28
Good to know
Dumfries
Will trigger voltage be a problem?
I very rarely use flash and don't want the expense of buying a P-TTL gun.
