S-M-C Takumar 28mm f/3.5
"Photography is a way of feeling, of touching, of loving. What you have caught on film is captured forever... it remembers little things, long after you have forgotten everything." Aaron Siskind
Bodies K20D, LTL 3, K1000d
Lenses Pentax 50mm, Pentax 135mm, Tamron 70-300 macro
you 'test' pictures are better than some of my attempts at a serious capture ! I especially like No.6
PaulM
Some are more equal than others
Best wishes, Kris.
I can't believe you got away unmolested with using the camera in St Pancras but what a fantastic space, so full of opportunities.
I love the Betjemin shot and the bronze statue. If you've not had to correct any verticals then the shot of the blue cast iron springers is remarkable. This will make an excellent architecture lens, albeit rather a"long" one on a small sensor.
Regards,
Robert Adams
Ernst Hass
The more I use these older lenses, the more I rather like them. I haven't used the 55mm much, I must give it an airing too.
I have often taken photos in St Pancras and have never had problems, but I have never used a tripod. I would ask first in that case.
K.
As for distortion, I agree, my 28s (and none are in this class) produce anything like the same amount of vertical bending as an equivalent zoom. I guess it's so much easier to make a prime optically stable (if that's the right expression). I also value the increased viewfinder brightness which you get.
So glad you're pleased with it.
28mm (42mm in predecimal): that's the way I see the world!
A.
Robert Adams
Ernst Hass
I assume it is the direct ancestor of the SMC "K" 28mm f/3.5.
Did you get any hassle from PCSO's or station staff taking shots in St Pancras?
R
R
K.
Did you get the rectangular hood and the two cases? If not they do appear on ebay quite a lot.
Very nice pictures too BTW.
K.
1. Spring growth.
2. No way in.
3. Old gate at Lamer
4. Miniature daffodils
Best wishes, Kris
Hertfordshire,
mostly.
None of the pictures below will win any prizes but I think I have found quite a nice lens!
1.
2.
3.
4.
5. Taken at f/3.5
6. Taken at f/3.5
Best wishes, Kris.
