Right angle finder for K20d
Posted 26/03/2009 - 22:30
I have a generic eBay purchased version that has adapters in to fit most DSLR's by a slide in plastic reducer.
Pros -
Easier to compose shots
Can have 1.12 or 2.5 magnification to assist in manual focus
Adjustable eye piece
Cons -
Loose fitting so can wobble around a bit
Have to change focus for the different magnifications
at 2.5x cannot see the display settings
Would I but one again - Yes because I like to do low level shots and in my opinion it beats the live view option.
Would I spend more than £25 on one - not really.
Jon
Pros -
Cons -
Jon
Posted 26/03/2009 - 23:43
Older Pentax refconverters will fit the K20D (the viewfinder fitting has stayed the same since the M series cameras I believe) although the Refconverter -A has a larger hole in the mounting plate so you can see the gubbins at the bottom of the A-series camera viewfinders. Only problem... they are quite pricey!
I believe the Seagull ones work OK... is that what you have Jon? I have a genuine Pentax one but for the Spotmatic series viewfinders.
I also have the FB-1/FC-1 and FE-1 finders for the LX which allow vertical viewing in the manner of the refconverters.
Check with Chris at SRS, they have various second-hand bits and pieces and may well have a refconverter.
Posted 27/03/2009 - 11:23
I have the Seagull RA finder which works well. The only weak point is the attachment adapter which is plastic; the unit comes with ones for the leading camera manufacturers including Pentax. If it were to fail, spares can be obtained in the UK. It has two magnifications 1x and 2x but at the 2x setting, the display settings cannot be seen.
It works fine with the K10D and is invaluable for low-level shots, eg. fungi.
It can be obtained online for about £30 including postage from Hong Kong (try Ebay).
John
John
Pentax K7, Pentax DFA 100 macro, Sigma 17-70 macro, Tamron 70-200 Di LD zoom macro, Vivitar 28 f2.8 CF, Tamron 500 mirror lens, Pentax 360FGZ flash, Panasonic FZ28
Posted 27/03/2009 - 11:29
I've got the Seagull and agree with with other comments. It works well but is let down slightly by the rather wobbly viewfinder attachment. The optics are suprisingly good though!
I paid around £30 (including shipping) from a Chinese eBay shop and I'd happily buy one again; it's not perfect but it's more than good enough.
Joining the Q
Posted 27/03/2009 - 12:16
I have the refconverterM but I cannot see the display on the K10. Is there a way around this. I thought I read somewhere of a method of altering the converter. Anyone with experience of such.
Posted 27/03/2009 - 12:36
Is it the one with 1x and 2x view. You can only see the full image at 1x on any camera. 2x is for focusing. I have the M.... no problems. They were made for full frame so I can't imagine that you can't see the display.
The one at SRS is very cheap, but make sure it's got the rubber eyecup.
shim
shim
Posted 27/03/2009 - 15:00
when using the angle viewfinder I am looking for the yellow confirmation signal that I am in focus. I cannot see this in either magnification. Should I be able to see this?
Posted 27/03/2009 - 15:27
Yellow? The focus confirmation indicator is green...
Posted 27/03/2009 - 16:25
..a green hexagon at the bottom of the viewfinder
Posted 27/03/2009 - 17:23
Old Olympus (OM type) ones also fit. They don't have the magnification option but thay can be picked up for about £30
Tony Milner
www.amilner.org
www.amilner.org
Posted 27/03/2009 - 19:34
Just checked on mine and I can see it at 1x and 2x. Just the corners and a bit left and right get cut off at 2x.when using the angle viewfinder I am looking for the yellow confirmation signal that I am in focus. I cannot see this in either magnification. Should I be able to see this?
shim
Posted 27/03/2009 - 22:48
shim
£129.00? Cheap? I think I'll stick to the Seagull...The one at SRS is very cheap, but make sure it's got the rubber eyecup.
shim
I don't suppose a dSLR will ever come with LX like viewfinders. Too many electronics :
South Wales,
UK
Cheers, Bob
