Reverse Nd Grads
Posted 16/11/2012 - 17:24
Although the Singh Ray option is not cheap, they are very good and worth the money if you do a lot of sunrise/set photography. I think Hi Tech is the only other option I know of.
Fletcher8.
Posted 16/11/2012 - 18:25
Stupid Q: What is a *reverse* ND grad?
Posted 16/11/2012 - 18:42
They have a clear bottom half and then a fairly harsh dark section getting progressively lighter to the top.
Tricky to use without the line showing I'd imagine.
Posted 16/11/2012 - 19:18
This is worth a read..
http://leefilters.uservoice.com/knowledgebase/articles/124041-reverse-nd-grads
Simon
Simon
Find me on Google+ link
Posted 16/11/2012 - 19:55
That makes a lot of sense.
Posted 16/11/2012 - 20:36
Ive actually done that.
Posted 16/11/2012 - 21:29
Thanks all for your replies thus far... Simon, I know you take a lot of landscapes yourself... And actually any one else out there who does as well... What's the best way you've found of controlling the very thin band of extremely bright (+ 3ish stops) light you get around the exact moment of sunrise/sunset on the horizon without over exposing the highlights or under exposing the rest of the frame? Do you use the method Lee/Tim Parkin suggest? Or stack normal grads and fix in post? Or bracket and combine in photoshop? I generally try to do as much in the camera as I can... But any suggestions on the best way to solve this (inc reverse nd grads !) would be gratefully received...
Thanks vmuch...
Thanks vmuch...
Posted 17/11/2012 - 13:31
So, an ND stripe with a hard edge at one side and soft edge on the other? They have a clear bottom half and then a fairly harsh dark section getting progressively lighter to the top.
Presumably the idea is to align the hard edge with the (utterly flat ) horizon?
Isn't that just like using an ordinary grad with the top edge in the middle of the frame?
Posted 17/11/2012 - 14:02
This thread is very helpful - thanks!
Never really thought about this problem before. The link to Tim Parkin's article via Lee filters is really worth reading
Andy
Andy
Andy
Thanks very much
Immersive
BillWardPhotography
Facebook
