result from bracketing
Posted 30/09/2008 - 22:04
Hi. If you look at the LCD display on the top of your K10D you will see three tick marks showing the three bracketed exposures, one of which will blink when you half depress the shutter button indicating the current exposure (in case you had forgotten how many you had taken). If you then dial in an exposure compensation you'll see all three little tick marks move as you do so indicating the level of compensation compared to the reading. So, +/- 1 stop bracketing with +1EV compensation will give you 0, +1 and +2EV shots.
Best wishes, Kris.
Best wishes, Kris.
Posted 01/10/2008 - 11:14
Hi Mannesty
Hate to correct you. Just fired some bracket shots. Set of 3: o, +2, -2.
Adjustment while holding bracket button and dial 3 or 5 bracket choice with rear wheel and 0.5, 1,1.5 or 2 brackets using front dial. This was on my K20D set in custom menu for 0.5 EV spacings (alt is 0.3). Thats probably clear as mud! See P 129 in the manual.
cheers
bb2
cheers
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
Posted 01/10/2008 - 11:22
Damn. You're perfectly correct. Sorry Mike, bum info. As BB2 says, press the button at top left of the camera back and use the front wheel to choose from Off, 3, or 5 shots, and the rear wheel for spacing.
Thanks for the enlightenment BB2.
Posted 01/10/2008 - 11:34
Additional note:
K10D - when using bracketing (esp for HDR), you should use a remote release. If you use the shutter you have to press it once for each bracketed shot.
K20D - there is a custom option to rattle off all bracketed images on one shutter press.
And yes, as noted, you can have 2Ev apart, either 3 or 5 shots. 2Ev/5 is what I use for HDR I even have it saved under the "User" setting How cool is that!
Posted 01/10/2008 - 12:01
Thanks for that Matt, i'm glad someone read the manual
Camera:|K-7|
Posted 01/10/2008 - 12:06
Page 130, and custom function "One-Push Bracketing" Thanks for that Matt, i'm glad someone read the manual
I'll send you the invoice later...
Posted 01/10/2008 - 13:39
beachboy2 wrote:
Hi Mannesty
cheers
bb2
Nice one, thanks for that
Hi Mannesty
cheers
bb2
Posted 02/10/2008 - 08:07
MattMatic wrote:
Additional note:
If you keep your finger on the button it will fire off 3 shots in sequence.
Additional note:
Birmingham
thanks
Gaz
