Requesting a favour from a K-7 owner
Mike-P
Posted 05/08/2009 - 17:15 Link
If it's possible could someone with a K-7 tell me if it is possible to take a pic out of a video shot in the highest quality and if so post a full sized .jpg here?
Thanks.
Greytop
Posted 05/08/2009 - 19:03 Link
Yes it's possible, here are a couple of quick and dirty frame captures.
Light wasn't the best.
[IMG]http://img268.imageshack.us/img268/8169/imgp1847i.jpg[/IMG]
[IMG]http://img268.imageshack.us/img268/7896/imgp1846n.jpg[/IMG]
Regards Huw
flickr
Edited by Greytop: 05/08/2009 - 19:04
smc
Posted 05/08/2009 - 21:46 Link
Wow. Interesting: so the K7 works at something like 30fps with this quality. Nice fast action camera if the AF worked!
Mike-P
Posted 05/08/2009 - 21:51 Link
Thanks for that ... quite reasonable quality.
timk
Posted 05/08/2009 - 23:08 Link
How do you grab the shots from a video?
Tim
K7, Sigma 10-20mm,DA 21,40,70mm Limited,DA* 55mm,DA* 16-50mm,DA* 50-135mm,Sigma 105mm macro,Sigma 70-200mm 2.8 HSM,Manfrotto 055cxpro4,Gitzo 1780QR,Metz 58
Greytop
Posted 05/08/2009 - 23:56 Link
Quite an easy process. Simply play back the video and pause at the desired point (with the four way controller, top button). Then press the exposure lock button to capture the frame and save (OK button)
HD video is surprisingly good and with the potential of the Pentax lens range at your disposal it can be quite an interesting creative tool
Regards Huw
flickr
timk
Posted 06/08/2009 - 00:19 Link
Thanks ,I really should read the manual
timk
Posted 06/08/2009 - 00:20 Link
Is there any way of doing it on the pc?
Greytop
Posted 06/08/2009 - 01:16 Link
Absolutely, the simplest way is to hit the print screen key when playing the avi file then open up MS paint and 'paste' then 'save as'.
Alternatively use your video editing software to capture frames (if it can) or a program like 'fraps' could probably do it too.
Regards Huw
flickr
timk
Posted 06/08/2009 - 02:33 Link
Cool Thanks
aminstar
Posted 06/08/2009 - 07:25 Link
Huw
what's the size/resolution of the image you manage to get that way?
Is it printable?
Greytop
Posted 06/08/2009 - 09:10 Link
Hi Amin,
the size of the image captured is exactly the same size as the movie format you select in settings.
In this case I have selected the highest movie resolution of 1536 x 1024 (3:2) so I guess you could use it for small prints, although I haven't tried it yet.
Regards Huw
flickr
aminstar
Posted 06/08/2009 - 09:22 Link
Thanks Huw
Anvh
Posted 06/08/2009 - 11:32 Link
With 1536 x 1024 you have a DPI of 256 when printing 4x6" (10x15cm) size so good for that size.
Stefan
K10D, K5
AF-540FGZ
