Removing Covid-19 from Cameras
Posted 18/03/2020 - 14:47
I used to sell disinfectant sprays when I was a dental supplier, and alcohol sprays denature plastics, so I don't know what the long term effect would be on the finish of the cameras.
This effect used to make the upholstery of dental chairs crack, albeit it over a long period of time.
I do use the Zeiss lens wipes from time to time.
Posted 18/03/2020 - 15:33
I would presume the camera can only have the virus on it from an infected owner and isn't the virus alive for just 72 hours on a hard surface ?
Chris
Posted 18/03/2020 - 16:39
Agreed to a point.
You could come into contact with virus (on hands) and handle camera without self-infecting (touching mouth, eyes, or anything that then touches mouth, eyes). That being said, if you've done that you've more than likely touched something that will also come into contact with your face (mouth, eyes, etc.).
Also yes, max 72 hours. I'd rather just 'dust' with some disinfectant wipes on the camera before use than force myself to wait 72 hours to use it again.
Posted 18/03/2020 - 16:41
Benz3ne wrote:
Agreed to a point.
You could come into contact with virus (on hands) and handle camera without self-infecting prior (touching mouth, eyes, or anything that then touches mouth, eyes). That being said, if you've done that you've more than likely touched something that will also come into contact with your face (mouth, eyes, etc.).
Agreed to a point.
Posted 18/03/2020 - 17:56
I think the key point in what SRS says about using alcohol spray is to dry with a towel. Presumably so the alcohol is on the surface long enough to kill the virus but not long enough to damage the surface.
And, of course, not all plastics are the same - I've had wine from bottles with plastic bungs (not 70% alcohol, of course...).
Posted 18/03/2020 - 18:22
What about surface tension: alcohols have about one third that of water - doesn't that make it easier for them to flow around WR seals? A wipe with an anti-bac damp cloth sounds better than alco-spray for cleaning the gear safely.
Philip
Philip
Posted 18/03/2020 - 19:01
Strong short-wavelength ultra-violet light?
SteveH!
I prefer 'unconventional'.
Posted 18/03/2020 - 19:22
Dual purpose, it’ll de-yellow old Takumar lenses too
Posted 18/03/2020 - 22:12
The sun tan parlours are going to be inundated now!
South Dorset
Weatherproof - Spray with a disinfectant solution that contains over 70% Alcohol, and dry with a towel.
Not weatherproof - Wipe down the exterior of your product with alcohol-based sanitizing wipes. We recommend choosing products that are labelled as effective for killing 99.9% of bacteria and viruses and also bleach-free.
Not sure - Treat as not weatherproof.
And make sure that caps and covers are closed.
Presumably they know what they are talking about!
