Remote shutter control for KS2 from iMac
Posted 19/10/2017 - 11:34 - Helpful Comment
Also this may give you some pointers - https://www.dpreview.com/forums/thread/3969445
K3ii, DA16-85, DA35mm Limited, FA77mm Limited, 55mm f1.8 K, 135mm f3.5 M, DA300, DA 1.4 HD TC,
DA16-45, Sigma 15mm f2.8. Cosina 100mm f3.5 macro
Posted 19/10/2017 - 12:31
Thanks for the replies. Unfortunately there is more Windows stuff available than OS X. My urgent need is more for remote controlling the camera than for file transfer. You can't so much as cough in the vicinity when you are doing a five minute exposure, despite my highly expensive tracking mount.
Posted 19/10/2017 - 16:29
It seems that I was able to run an Android emulator (Nox App Player) with Image Sync on my iMac and that will talk via Wifi to the camera ok. Ir will control the shutter. So I am nearly there. It's a shame that Image Sync is so limited, though. Ideally, I would like to set the sequence of ten exposures of say two minutes each and then go away for a cup of tea. The present system involves pressing a button to get a result. Never mind. The night, by definition, will be pretty clear and there are stars and things to look at with my binoculars.
Posted 19/10/2017 - 16:37
One of these will let you do that. (You'd have to set the exposure on the camera, the control device will fire the shutter at set intervals.)Ideally, I would like to set the sequence of ten exposures of say two minutes each and then go away for a cup of tea.
A K-3 or K-1 will also let you set that up too, the KS-2 is more of a consumer model rather than have those pro features which might confuse the uninitiated!
An uprated Image Sync program is available on CD (Image Transmitter 2) https://www.bhphotovideo.com/c/product/1095284-REG/pentax_38553_image_transmitte...
Not cheap however and don't believe it is compatible with a KS-2!
If the KS-2 offered everything the top end models do, why would anyone buy them?
Does anyone know of some suitable software? I could run to a PC laptop if really necessary.
There is a USB port but I have no clue how to do anything other than file transfer that way. (Same with the HDMI socket)
