remote control using bulb
Philipp
Posted 08/11/2009 - 13:15 Link
I'am looking for a remote control for my K20d, for using it at bulb.
It should have a lock function, so that the first click opens the shutter and let it open till I click again.
Is there any remote control which has such an option, from Pentax or a cheap third party one, maybe from Delamax etc.
K20d, DA 16-45
Canon F1,F1N and many Fd lenses
Edited by Philipp: 08/11/2009 - 13:15
Anvh
Posted 08/11/2009 - 13:56 Link
I have a remote controll with a slide that slides over the button and keeps it pressed in.
Would that do the trick?
You also have electronic remotes that you can automate.
Maening saying it must make shots with intervals and most of them has a bulb timer.
Stefan
K10D, K5
AF-540FGZ
Philipp
Posted 08/11/2009 - 14:10 Link
A slider over the button will do it. Can you tell me the name of it?
K20d, DA 16-45
Anvh
Posted 08/11/2009 - 14:13 Link
Most of them Have it I believe, mine is a cheap Hama one for the canon xxxD series.
The connection of the canon 450D for example are the same as pentax, that would expand your range what you can use quite a bit.
Stefan
K10D, K5
AF-540FGZ
hefty1
Posted 08/11/2009 - 14:16 Link
It's called a remote shutter cord - eBay is awash with them for very little money (this is the first one I came across but just search for "Pentax remote" and you'll find hundreds).
Any remote with a 2.5mm jack will do - you'll find many more being advertised for Canon as their cameras also use a 2.5mm jack meaning the remotes are completely interchangeable.
Joining the Q
Philipp
Posted 08/11/2009 - 15:24 Link
So there is no infrared remote which supports a lock function.
I will go for a remote shutter cord.
Thanks for your help
K20d, DA 16-45
gartmore
Posted 09/11/2009 - 08:44 Link
moved to the correct place
aminstar
Posted 09/11/2009 - 08:47 Link
Yes there is. Check with SRS.
I got one, worked with K20D. Its great because it comes with the option of using it with the cord if you prefer, if you want to use infra red all you have to do is just unplug the cord.
The slider on the side if activated each push of the button activates the shutter release and another push of the button stops it. Let me see if I can find the item on SRS site
Edited by aminstar: 09/11/2009 - 08:49
gartmore
Posted 09/11/2009 - 08:48 Link
AFAIK you cant do it with IR, the battery would run down quite quickly.
aminstar
Posted 09/11/2009 - 08:56 Link
link
This one has a small slider on the left side, if you use it with the BULB function in the camera each push of the button will activate the shutter release. First one to open it up and next one to stop it.
And it comes with a cable with pins on the ends, you insert one pin underneath that access you see on the bottom of the remote and the other goes into the camera and you have a cable release remote too as an option when prefered
Edited by aminstar: 09/11/2009 - 08:57
Philipp
Posted 09/11/2009 - 14:03 Link
Thats exactly what I'am lokking for,
thanks for the help
K20d, DA 16-45
aminstar
Posted 09/11/2009 - 15:45 Link
thanks for the help
Always happy to help.
I am sure you will enjoy the remote, that one has lived practically in my pocket everytime I am locked in the shed, helping me get countless hours of pleasure while puffing some smoke
Smeggypants
Posted 10/11/2009 - 06:12 Link
aminstar wrote:
thanks for the help
Crikey you'd forget to close the shutter!! 6 hour exposures!!!
aminstar
Posted 10/11/2009 - 06:19 Link
I would have to be too stonned to forget to close the shutter .
But you never know, it could happen
