remote and K10D autofocus problems
Ava
Posted 18/02/2008 - 17:47 Link
My remote seems to work pretty well with my K100D. The lens usually focuses pretty well before the shutter is released. I am finding that even though I set in the custom settings to autofocus before the shutter is released, the K10D is not doing a very good job of that.
I have been doing some self portriture that requires I use the remote. I am finding that I need to try to focus first on an object near a place that I will be standing/sitting. It would be much easier if the remote triggered the autofocus, and it would actually work correctly.
Has anyone had this problem, or have any ideas about why it is not working as accurately as it should?
Classvino
Posted 18/02/2008 - 22:17 Link
If your camera happens to lock onto anything else to focus on, you're pretty much out of luck - I always either set mine to spot (if the subject is central) or pre-focus and turn the AF on remote off... (there may be better methods...)
When you're not looking in the viewfinder, if you're on a mode that selects a focus point automatically, you can never be sure just where that'll be...
MZ-6,K10D,K20D,Grip,DA*Zooms,DA 18-55-200 Kit,FA50,1.7TC,AFZ360
For Saleentax FA28-90,FA100-300,Sigma EX28-80,DC18-200,
Makinon 500mm Mirror
smc
Posted 19/03/2008 - 14:44 Link
I usually prefocus and switch off AF. With a smaller aperture, DOF can take care of some focusing error.
Mongoose
Posted 20/03/2008 - 09:36 Link
with the K10D you can also consider user selected focus point mode as an alternative to spot focus when the subject isn't central.
but it does help
amoringello
Posted 20/03/2008 - 10:38 Link
Is the main problem that the remote does not cause AutoFocus? Or that the camera does not focus where you expect?
There is an option to turn on/off AutoFocus on remote - [C Custom Setting] Menu. Make sure that is on.
[Edit]
I guess that is also what Classvino referred to, but I misread the first time around...
