recommend a macro lens please
dinneenp
Posted 03/06/2011 - 15:19 Link
Up until now I've been using my compact for 'macro' shots and have been happy with it. Sample shot- http://www.photoblog.ie/2011/05/15/drops-of-sunshine-2/
But obviously a dedicated macro lens on a Dslr has to be better so I might as well buy one, try it out. If I don't like it I can sell it.
Points of note-
1. Currently I think I'd use it more for stationary things (e.g. toothbrush head, bubbles in a pint etc) rather than birds etc.
2. I don't pixel pick so I'm just looking for a dedicated macro lens (1:1 would be best I presume) for the cheapest price possible.
3. My gut feeling is to go for an auto focus lens. BUT I'd go for a manual lens if it's a lot cheaper and easy to use (as I'd be shooting static items I'd imagine it'd be easy).
I've noticed that a lot of dedicated macro lenses have a long focal point e.g. 90mm. In my head (I could be wrong) this means that if I have something on the kitchen counter or somewhere I have to stand above it a fair bit/stand back a fair bit.
Are most macro lenses a long focal length and if so why?
So can you recommend me a lens or two please? I'm also open to the idea of a Raynox macro thingy or anything else....
My current lenses are-
Sigma 30mm f1.3
Pentax 18-150mm lens
Pentax (or Tamron) 17-50mm f2.8
I bought an extension tube for €7 on Ebay but never got it to work properly- there's a pin or something missing so it gets stuck every time and I have to 'work it off'.
Thanks in advance,
Pa
Cheers,
Pa
Edited by dinneenp: 03/06/2011 - 15:26
Cuchulainn
Posted 03/06/2011 - 15:28 - Helpful Comment Link
If you're using it mainly for macro, then a manual focus lens will work fine. However, as macro lenses tend to be so sharp, you'll find yourself using them elsewhere and AF will be handy. As an example, my 100mm macro is one of my favourite lenses by quite a long shot.
For 1:1 reproduction, the object will be about the focal length in front of the lens (so 100mm for a 100mm lens) - there will be a little give or take depending on the exact lens design, but only a few cm at most. So 100mm is still going to be pretty close to the subject in most cases. This is why you'll hear people complaining about the lack of the Sigma 180mm macro lens in pentax mount!
The Tamron and Sigma 100mm-ish (one is 90, the other 105mm) lenses are good AF lenses. The Pentax and Samsung 100mm lenses are all good. A Tamron 90mm adaptall, vivitar 100 or 105mm or even the cosina 100mm will all be decent cheap alternatives too (though cheap in this case is still more than £100 at best).
Posted 03/06/2011 - 16:18 Link
Some compacts make macro photography a breeze, so I wouldn't discount them at all. Have a look at what CarolG on ePHOTOzine achieves. Would she be better with a DSLR - I doubt it.
However, with a DSLR it will have strengths of its own and the dedicated macro lens is definitely the way to go.
Mannesty
Posted 03/06/2011 - 17:18 Link
Pentax have 3 true macro lenses in their current lineup, at 35, 50, and 100mm. All are AF/MF, but I wouldn't be put off buying an older MF only lens. To any of those you could add extension tubes or a bellows to get greater than 1:1 magnification.
You'll get varying opinions about which lens to use for which subject. Here's mine. The 35mm is good for static subjects. The 50 is good for static and live, but sedate subjects. The 100mm is the one to go for for taking pictures of bugs in general.
There is a SMC Pentax-FA 200mm macro lens in the wild. If you can find one, it'll set you back somewhere between £1500 & £2000. The Sigma 180mm EX DG 1:3.5 macro lens is about the nearest you'll get to the FA 200mm. It's my favourite lens.
Birds are not usually considered to be a subject for macro-photography because to get 1:1 magnification, you need to be too close.
Edited by Mannesty: 03/06/2011 - 17:23
Epithet Man
Posted 03/06/2011 - 21:46 Link
Shorter focal length makes it easier to hand hold, but to be honest you're going to need to use a tripod for most serious work. If you're afraid of spiders (or toothbrushes in your case) then maybe you need something slightly longer.
I have a Sigma 105mm/f2.8 AF macro lens. To be honest, I use it more for (brutally sharp) portraits than macro shots. When shooting macro I tend to switch it to manual.
By the way, the bubbles in my pint are definitely moving, although there are more of them than birds. That didn't quite come out right
EM
Dangermouse
Posted 03/06/2011 - 23:44 Link
Prices have got silly, but the old Pentax 100mm f4 (sold as SMC Pentax and SMC Pentax-M, same lens, different lettering) still holds its end up pretty well judging by the test shots I've seen. I seriously considered buying one but realised that I don't do much macro photography.
One trick which might come in handy - if you want an extension tube with the A contacts and see a PK-A fit teleconverter you can usually unscrew the elements to convert it into an extension tube. I did this with an old Jessop 2x TC (no loss, cropped images from my 200mm f4 were better than images with the same lens plus the TC!) and it worked perfectly when I tried it with my Samyang 85mm, which otherwise has a minimum focus distance of about a metre.
claudefrog
Posted 06/06/2011 - 10:24 Link
I can honestly recommend the Sigma 70mm Macro f2.8 1:1 as it acts as a duel purpose lens, superb for Macro but doubles up as a fantastic portrait lens, sharp as a tack.
Pentax k-5
Metz 50 AF-1
Pentax SMC 50mm 1.4
Sigma 70mm 2.8 MACRO
Sigma 17mm-70mm F2.8 - 4
Pentax 18mm-55mm f3.5-56 DA WR
Pentax 50mm-200mm f3.5-5.6 DA WR
dinneenp
Posted 06/06/2011 - 11:23 Link
Thanks for the replies.
Just a few more questions:
What's the cheapest I'd get a 1:1, f2.8, any focal length, auto focus for?
And what lens with 1:1 would be the cheapest (any focal length, any aperture)?
Or less magnification but with extension tube or whatever else is needed?
Lastly are the Raynox thingys any good?
Thanks,
Patrick
Cheers,
Pa
i-Berg
Posted 06/06/2011 - 11:55 Link
The Tamron 90 mm f 2.8 is worth a look too - a very good performer.
Kim C
Posted 06/06/2011 - 12:28 - Helpful Comment Link
Difficult call. My favouite and an absolutely fantastic lens is the Voigtlander 125mm Apo Lanthar. It is going for silly prices though. The last one in PK mount on that site went for nearly £2000!!!!
If 1:1 is important the there are the Pentax 2.8 lenses in various guises. If 2.8 is not that important and you can make do with 1:2 then there is the older 100/3.5 Pentax macro. It feels flimsy, almost cheap but it is capable of very good results and is AF.
Most of the others are covered above.
Kim
dinneenp
Posted 06/06/2011 - 13:30 Link
Is there a big difference between 1:1 and 1:2?
I know it's 1/2 the magnification but what do most people use etc.
Cheers,
Pa
Mannesty
Posted 06/06/2011 - 13:52 Link
1:1 and greater here.
All of my macro lenses can produce 1:1 magnification. With tubs and/or bellows, greater magnifications are possible with trade-offs.
dinneenp
Posted 06/06/2011 - 14:26 Link
Last question: so what's the cheapest I'd get a 1:1 autofocus lens for?
Thanks.
Cheers,
Pa
thoughton
Posted 06/06/2011 - 15:03 Link
On the MF front possibly a Tamron. The f2.8 version of the 90mm Adaptall-2 models (model 72B IIRC) is 1:1 without extension tubes, I would be looking to pay about £100-125 for one (without the mount). The other 90mm models are 1:2.
AF I'm not sure. There is an inexpensive AF Cosina macro that pops up on ebay every now and then, it might only be 1:2 though. Last one I saw sold for about £150ish.
Tim
rparmar
Posted 06/06/2011 - 16:04 Link
The Cosina macro is excellent IQ in a plastic build for little money. It is 1:2 but comes with an matched adapter for 1:1. But get the manual focus version as it's better (apparently - I do not own both). Not sure why you'd want autofocus for macro, especially in the 1:1 range.
Listen to my albums free on BandCamp. Or visit my main website for links to photography, etc.
