Rechargeable 2cr5 battery for PZ-1p
Anonymous
Posted 28/11/2003 - 09:43 Link
Dear Friends!
Have anybody tried to use rechargeable 2cr5 battery for Pentax PZ-1p
sold in the UK:
http://www.2cr5.co.uk/acatalog/Online_Shopping_Rechargeable_2CR5_Batteries_and_C...
Or have anybody tried Nikon EN-EL1 battery from Nikon Coolpix cameras to use with PZ-1p?
Anonymous
Posted 28/11/2003 - 09:54 Link
Nikon EN-EL1 is replacement battery for 2cr5 for use in Nikon Coolpix
digital cameras, it probably shoud work with Pz-1p, but it should be tried
first.
Posted 28/11/2003 - 11:41 Link
Steve,
Not really sure why you would want to when you can get the 2CR5s so very cheaply from http://www.7dayshop.com (£2.09 each)
The rechargables will be lower voltage than the lithium, so don't hold out too much hope for the EN-EL1. However, if you've got both, it's worth a try
Anonymous
Posted 03/12/2003 - 10:34 Link
Rechargeables EN-EL1 are higher voltage than 6V 2cr5 - it is
about 7 volts and something, I think it should work fine, I would
buy it, but I must buy also charger.
Cheap batteries - I can forget it in my country - here such a battery costs
400 slovak crowns = 9 US dollars!!!!
Anonymous
Posted 12/01/2004 - 10:59 Link
If somebody has (P)Z-1p and has some friend with Nikon Coolpix camera with EN-EL1 battery, please write here if it worx
thanX
Anonymous
Posted 08/03/2004 - 15:37 Link
Hi guys,
I've bought a coolpix4300 and the accu I'm using is the EN-EL1 and it works very well
good luck
grtz Roel
Qwntm
Posted 03/04/2004 - 01:51 Link
When the PZ-1 first came out, I was using them for weddings, It got expensive in terms of batteries, so I took apart a spent 2cr5 and ran some wires to a 4-AA battery holder which I mounted under the camera. It worked great. I had to make a little hole in the corner of the battery door for the wires, but other than that it just screwed into the tripod socket.
(Kind of like a poor mans MZ-5 battery grip.)
If the batteries are that expensive where you are you might want to fiddle around and see what you can come up with!
Good luck!
