raw converter
johntd
Posted 06/06/2010 - 10:55 Link
I would like to know if the raw converter plugin for Photoshop will work for raw from my K100
J Dunkley
Anvh
Posted 06/06/2010 - 11:57 Link
Which photoshop do you've?
Stefan
K10D, K5
AF-540FGZ
johntd
Posted 06/06/2010 - 12:17 Link
Hi Stefan, I have Photoshop 7
J Dunkley
Anvh
Posted 06/06/2010 - 12:38 Link
You need to have Adobe Camera Raw 3.6 or up so that means CS2 and up.
Photoshop 7 does support DNG so you can use this converter Windows - Mac
Other option would be update photoshop or get another RAW processor like Silkypix, Phaseone or Lightroom, for example.
I don't think you can find any plugins that work.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 06/06/2010 - 12:39
johntd
Posted 06/06/2010 - 14:57 Link
many thanks for your input, I will look at other means.
J Dunkley
DragonDrop
Posted 08/07/2010 - 15:58 Link
Adobe Photoshop Elements 6 does process PEF (ie RAW) files. When you open a PEF file it runs Adobe Camera Raw for you. So I would think that Photoshop 7 should also handle them???
Absinthe makes the heart grow fonder.
Pentax k100d, kit lens & Tamron 70-300
DragonDrop
Posted 08/07/2010 - 16:02 Link
see also this link to adobe . I think that I added that update to my PC so that I was using the latest Adobe Camera Raw (version 4.3.1). I use gimp under linux now though.
Anvh
Posted 10/07/2010 - 12:04 Link
Yes and no.
PEF isn't actually PEF, there are slight variation of them between camera models so the PEF from the K100D is different than the PEF of the K20D.
That means Adobe camera raw need to support the PEF of that camera model.
Like you show in the comment after that you will see you need Photoshop CS2 to run that Adobe camera RAW needed for the PEF of that caemra so photoshop 7 won't do
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 10/07/2010 - 12:06
andrewk
Posted 10/07/2010 - 12:18 Link
I don't think so. I used Photoshop 7 until recently and the freebie RawTherapee (RT) for RAW conversion. RT is pretty good (my PEFs are from a K200D - so check), but avoid it if your PC has Windows 7, as RT hangs on a regular basis - most annoying.
The best bet might be to buy Photoshop Elements 8. I got it off Fleabay for less than £40, but you can get it from several places for a little over £50. Once you get it, download Camera Raw 6.1 from the Adobe site - works fine for me.
Edited by andrewk: 10/07/2010 - 12:20
