RAF BBMF - Once in a lifeltime opportunity - help!
Mike-P
Posted 01/04/2014 - 20:56 Link
For what it's worth and to give you an idea of size.
115mm
280mm (even 1/125th is really to fast to get decent blur on the propellers with the Lancaster)
fritzthedog
Posted 02/04/2014 - 19:55 Link
Thanks Mike really good advice - have managed to get the Lancaster in the past with decent prop blur but not great images
Such as this one at 400mm 1/125
Or this one at 350mm
Carl
ChrisA
Posted 02/04/2014 - 22:54 Link
Mike-P wrote:
You are photographing the Lancaster?
In which case it's very unlikely you will need anywhere near 500mm, depending how close you are I would imagine 300mm would be a bit much as well. Personally I would be looking at the 10-20mm for quirky wide shots, 17-70mm for people/portrait/interior and the 70-200mm or 120-400mm for the Lancaster photos (really depending on available light on the day)
As for settings ... AF.C, centre focus point, TAv mode, shutter speed will need to be in the 1/250th region (to get decent prop blur ... nothing worse than a prop plane in the air with a static propeller) and an aperture that gets you a decent ISO. As with all panning, keep following the plane for a moment after pressing the shutter button.
Personally I would be up the airport practising as it's unlikely you will get a second chance at this ... very jealous btw.
Very much agree with all this, especially the bits I've put in bold, and most important of all the practice.
Even if you can't get to Humberside, get to an airfield somewhere and hang out near the aeroplanes, if you haven't already spent time doing this.
I'd say 1/250 is at the short end of the exposure range unless it's taking off and you might get away with a little shorter.
I wasn't aware of the Canadian Lanc coming over, but if I have some time, I'll be looking to get some shots of them both in the air. That is the holy grail, really. Quite likely a literally once-in-a-lifetime thing, to have both of them.
The K-5 AF should be Ok for the Lancaster; it doesn't go very fast...
If it's manoevring around, 500mm might be useful, as it was with a couple of these...
[IMG]http://i162.photobucket.com/albums/t244/chris5gd/Aviation/Farnborough%202012%20July%2015/IMGP2693.jpg[/IMG]
See what I mean about 1/250 really being a bit on the short side - the above is 1/200.
As is this, not that you can tell with the props edge on...
[IMG]http://i162.photobucket.com/albums/t244/chris5gd/Aviation/Farnborough%202012%20July%2015/IMGP2691.jpg[/IMG]
[IMG]http://i162.photobucket.com/albums/t244/chris5gd/Aviation/Farnborough%202012%20July%2015/IMGP2682.jpg[/IMG]
But if you're close, even 75mm is ample...
[IMG]http://i162.photobucket.com/albums/t244/chris5gd/Aviation/Farnborough%202012%20July%2015/IMGP2603.jpg[/IMG]
Edited by ChrisA: 02/04/2014 - 22:59
Mike-P
Posted 02/04/2014 - 23:03 Link
I got totally caught out with this one ... my back was to the runway and I was chatting away to someone, turned round just as it came over the top and the lens was at 400mm. Didn't have time to pull it in.
ChrisA
Posted 02/04/2014 - 23:08 Link
For shame!
Though it is surprising how sometimes a crop can be very effective. I like this - very lucky with the light - presumably reflecting off pale concrete or something?
The gear's up - was it a low pass?
Edited by ChrisA: 02/04/2014 - 23:09
Gamka
Posted 02/04/2014 - 23:37 Link
That is excellent - it gives the impression it is just feet above you whereas if you had the full span it would look far away.
tyronet2000
Posted 03/04/2014 - 11:40 Link
Thanks to all for the great shots and the great advice
Stan
