Quick release tripod heads
browngo1
Posted 04/09/2007 - 16:31 Link
Looking for some advice on tripod heads. I have been looking at ball type heads, but don't know whether to go for the plain screw in type or the quick release type. I understand that the plate is fixed to the camera and then clamps/clicks on to the head instead of screwing the complete head on to the camera. Is the plate something you would leave on the camera permanently (I don't have a bettery grip)? Or is the quick release type only something you would buy if you were going to do a lot of tripod work?
Gordon
K10D
niblue
Posted 04/09/2007 - 16:36 Link
I prefer the ones with a quick release plate. I don't leave the plate on the camera permanently, however I do fit at the start of any trip where the tripod might be used so it's always available.
My K10D is wearing a quick release plate at the moment and I don't find it gets in the way at all.
Mannesty
Posted 04/09/2007 - 16:43 Link
I prefer quick release (QR) plates. For long lenses however, you might need to remove the rubber pad that the lens/camera sits on as it can cause the camera/lens combination to be somewhat less than rigid. I had to do this in order to reduce the movement of my SMCP 135-600mm zoom. Its tripod mount is too far back and leaving the rubber pad in place just wasn't working.
I don't usually leave a plate on the camera but all of my lenses that have a tripod mount have their own QR plate permanently attached.
If you a swapping long lenses, having only one QR plate is about the same as having none.
Daniel Bridge
Posted 04/09/2007 - 18:07 Link
The plate's normally on my camera, even when I'm not using the tripod, otherwise it's just something else to lose. I have the battery grip on my K10D, and the manfrotto QR plate I use (the common one) isn't big enough to cause a problem.
Definitely much better than screwing the camera to the tripod every time!
Dan
browngo1
Posted 05/09/2007 - 09:03 Link
Once again, thanks for all the advice, it's much appreciated and very helpful. Looks like I'll be going for one with a QR plate.
Gordon
K10D
