Question regarding 360 flash unit
Hiljon
Posted 05/08/2009 - 00:34 Link
Now I got the flash and having read the manual between patients I seem to be getting to grips with it. However, I have a question ... using with a K200D, can you use the 360 flash in a wireless set up, but only have the 360 fire and not the camera pop-up - say for side lighting. I may have misread, but it seems that you have to have the pop-up fire as well in a wireless environment.
Thanks for the help thus far.
George Lazarette
Posted 05/08/2009 - 00:45 Link
Wireless is a bad name for the Pentax remote flash triggering system. It doesn't work by radio, as the name implies, but by sending out short pulses of light from the camera-mounted flash to the remote flash.
That means you have to have a camera-mounted flashgun as well as a remote. If you turn off the flash on the camera, you won't be able to fire the remote.
Aero
Posted 05/08/2009 - 02:38 Link
As an experiment, it might be worth taping an infrared filter over the pop-up flash to see what happens. I seem to remember that slave flashes are generally triggered by IR rather than visible light, so this set-up might trigger the 360 without upsetting your lighting. You can buy sheet filter material through this link and presumably at many other outlets: link
Best of luck
Al
Aero
Posted 05/08/2009 - 03:07 Link
On second thoughts, if the pop-up flash doesn't emit visible light, the camera won't be able to calculate the exposure information it needs to pass on to the 360. More to this problem than meets the eye. Oh well
Al
Don
Posted 05/08/2009 - 03:25 Link
Buy Mattmattics ebook.
trust me.
I'm a pro and even I found that book useful
George Lazarette
Posted 06/08/2009 - 16:48 Link
Aero wrote:
As an experiment, it might be worth taping an infrared filter over the pop-up flash to see what happens. I seem to remember that slave flashes are generally triggered by IR rather than visible light, ...
Al
You are confusing flash triggers, for use with studio lighting, and wireless flash technology. The former use IR, the latter use proper light.
Anvh
Posted 06/08/2009 - 17:23 Link
I believe it does need IR though but it still needs the pop-flash to reliably trigger the external flash.
Over the IR signal goes the flash output information and such I believe.
Here is a demo video from Pentax link
Stefan
K10D, K5
AF-540FGZ
George Lazarette
Posted 06/08/2009 - 20:19 Link
Why would it need IR when it is using visible light to communicate?
Oggy
Posted 06/08/2009 - 20:55 Link
[pedant] Actually although "wireless" is generally associated with radio frequency electromagnetic transmission it actually means what it says - no wires. It could equally refer to infra red, ultrasonic or other transmission of a signal or data using energy. It would be applicable to visible light. [/pedant]
George Lazarette
Posted 06/08/2009 - 21:48 Link
Quite so, but I suspect you are a trifle younger than me. In my day, the wireless was the radio. We didn't have a gogglebox.
fatspider
Posted 06/08/2009 - 22:23 Link
Now I could be wrong (often am) but if the 200D is the same as the 20D you will have two options in the custom function menu, "fire built in flash as MASTER" or "fire built in flash as CONTROLER" firing as MASTER will add the built in flash output to the subject while firing as CONTROLER will make the built in flash emit just enough light to set off the slave, in this case the 360FGZ.....simples
My PPG link
My Flckr link
Anvh
Posted 07/08/2009 - 11:33 Link
Seems my video in the first one doesn't work.
Click on DEMO on the left side link
George I'm going to quote what they say in the video okay.
- shutter button is pressed
- controller flash emits "control flash burst"
- Wireless unit flash emits "Preflash" so that the camera can determine the amount of flash needed
- Controller flash emits "control flash burst"
- Wireless unit "fires"
and you're quite right they don't talk about IR so quite amazing they can sent all the info needed in such a small time.
Stefan
K10D, K5
AF-540FGZ
gartmore
Posted 07/08/2009 - 11:59 Link
The BBC, until recently, still referred to it's 'record collection' as the Gramophone Library.
Ohawa
Posted 14/08/2009 - 10:04 Link
About the wireless flash trigerring - I find it very useful in white or brigt painted rooms (not too large, at most approx. 7x7x4 meters)with bright ceiling. Quite often I shoot at ISO 200 with the wireless AF360FGZ lying on a desk flashing toward the ceiling or a wall. Unexpectedly nice and sharp pictures, almost no ghosting. Only slightly red eyes but this can be removed.
Btw wireless doesn't seem to support high speed sync even when ISO is fixed (not auto ISO, then the high speed sync doesn't work anyway), am I wrong?
Anvh
Posted 14/08/2009 - 21:47 Link
I believe it works when you use a external flash as master flash on your camera regardless the ISO.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 14/08/2009 - 21:47
