Quality issue with TC
Posted 07/04/2010 - 10:51
Have you a control image taken of that subject without the TC per chance?
Posted 07/04/2010 - 10:53
Good point!! No actually. I was basically looking to see if anyone thought that this image showed signs of having a TC attached.
I will do two more. With/without TC.
Posted 07/04/2010 - 11:04
Also, it might be helpful to show a 100% crop on an in-focus area
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Posted 07/04/2010 - 14:41
Posted 07/04/2010 - 17:06
The with TC looks softer to me.
Could you post an example of the "without TC" blown up to the same size as the "with TC" example. That would give a better idea if there was any advantage to using the TC and not just blowing up the original.
Greg
Greg
Posted 07/04/2010 - 17:37
There is definitely more detail in the non-TC image...
Terry
Terry
Posted 07/04/2010 - 20:45
gregmoll wrote:
Greg
These are 100% crops of the original jpg. To blow up the non TC to the with TC means pixelation.Hi,
Greg
Unless I'm missing something. If so let me know.
Posted 07/04/2010 - 21:16
Talking from my perspective, I try to make the subject fill the view finder so as to get the maximum size image on the sensor, obviously by moving nearer or further away. However if I can not get any closer and using the same lens then I must use a converter to get the maximum size image on the sensor.
My interest was in trying to see if the non TC image crop is better than the TC image when viewed at the same physical size on the screen.
Bit convoluted but I hope you understand my meaning
Greg
Greg
Posted 07/04/2010 - 21:46
I've opened both pictures in Elements and matched their physical size by zooming in and out,133% and 75% if anything the No-TC version still has a slight edge over the TC version, but only very slightly.
Greg
Greg
Posted 07/04/2010 - 22:26
Greg
Accepted Greg. My original post was more of a "blind loudspeaker test".I've opened both pictures in Elements and matched their physical size by zooming in and out,133% and 75% if anything the No-TC version still has a slight edge over the TC version, but only very slightly.
Greg
Which speakers are you listening to?
Does it look that bad whereby someone could say it had a TC on the lens?
Posted 08/04/2010 - 07:53
Honestly, I am sure nobody could say that there was a TC behind the lens in your flower picture. To me, both focus and exposure look spot on.
Terry
Terry
Posted 08/04/2010 - 12:03
On the subject of t/c i shot this one over easter with my Pentax F 1.7 converter I aquired last year. I used it with the DA* 60-250 , and I am quite pleased with the results.
Wide open indicated f/4.5
