Q repair?
Posted 19/08/2021 - 17:21
When my original model Q developed the fault after 20 months it was replaced (by SRS) rather than being repaired. Whether this was due to the difficulty of repairing the camera or just economics I don't know. I've seen replacement circuit boards on eBay but they are in America so along with the shipping and other costs they are very expensive by the time land on the doormat here. I've never tried to disassemble my Q so I can't comment on how easy it would be to change out a board. FWIW my replacement camera still works fine today.
I also have a Q-S1, which is my Q of choice, which also developed the fault after several years. I have learned to live with the fault. I like to geotag my pictures so it is important to me that the camera clock matches my GPS or more recently my watch. So now when I change my battery I just take a picture of my watch or GPS. I then use "Edit Capture Time" in Lightroom to correct all the timestamps for all the pictures taken with that battery using just a couple of clicks. I guess other applications have similar functionality
Posted 19/08/2021 - 19:09
I find that if I change batteries very quickly, there's a good chance it will remember date and time. But it must be very quick - replacement close to battery door and right way round, open door, out with the old and in with the new, no hesitation or fumbling. No guarantee that it will work with anyone else's Q though .
Someone on the American forum dismantled a Q and posted pictures. It's not for the faint hearted!
Posted 19/08/2021 - 21:18
Many thanks for the comments. With my red/grey Q-S1 it loses the date and time every time I turn it off (or it turns itself off), not just when you change the battery (which is what happens with my original Q).
I'm not going to try DIY. Cack-handed doesn't even begin to describe my abilities at delicate tasks.
Thanks, Kris.
Thanks, Kris.
Posted 19/08/2021 - 21:35
I did a bit of googling when I first saw this topic and users were saying the Q-S1 used a different battery/method than the other Q cameras. This backup battery might now be 'dead' in your example, Kris.
All the gear with no idea
Posted 19/08/2021 - 22:10
It's also possible to set the time and date without realising that there's one final setting confirmation, otherwise the settings will be lost.
Posted 20/08/2021 - 18:29
And the key to the success of this trick is to ensure the battery you are about to remove is not completely dead. Turn the Q on and leave it on for 5 - 10 mins. (It will switch itself off after 5 mins so turn it on again straight away) This will ensure that when you do remove the battery, the Q's capacitors will retain some residual charge and thereby keep its settings. As Lubbyman points out though, the battery exchange needs to be performed as quick as possible if it' to be successful.I find that if I change batteries very quickly, there's a good chance it will remember date and time. But it must be very quick - replacement close to battery door and right way round, open door, out with the old and in with the new, no hesitation or fumbling. No guarantee that it will work with anyone else's Q though .
I know it works as I have an original Q which manifests this problem and it works for me.
Good luck.
C.O.L.B.A.S victim
Hertfordshire,
mostly.
I thought I could just live with it but it is driving me nuts...
K.
