Purple fringing - how to remove?
smudge
Posted 18/01/2011 - 17:07 Link
When reading lens reviews I often see comments like 'this lens suffers from some purple fringing but this is easily removed in processing'. I use PSE 8 and have yet to uncover this facility (other than by laboriously cloning). Am I missing something or does PSE not have this feature?
Regards, Philip
Edited by smudge: 18/01/2011 - 17:09
JonSchick
Posted 18/01/2011 - 17:16 - Helpful Comment Link
Quite often, the easiest way that works quickly and adequately is to go into the options to adjust hue/saturation. Make sure you are viewing the image pretty large (at least 50% possibly 100%).
Click on the drop down menu and choose magentas.
Click on the fringing in your image with the eye-dropper tool to choose the right colour.
Reduce the saturation (using the slider) and possibly also adjust the lightness slider.
This generally ought to do the job OK - and it's very quick.
There are more complicated things you can do which others might advise you on, or you could pay for the PT Lens plug in (works with PSE) from E Paper Press. This has a whole load of built in lens corrections and allows you to correct for chromatic aberrations too. It's pretty good and excellent value for money. You can set it up to correct distortions automatically for most readily available lenses - very handy!
Hope this helps,
Jon
Jon
Some occasional random stuff at The Photographers Block: link
smudge
Posted 18/01/2011 - 17:30 Link
Thanks Jon, I'll go and have a play...
Regards, Philip
smudge
Posted 18/01/2011 - 17:41 Link
Yup, that method works nicely. I've had PSE for almost a year now and I'm still only scratching the surface of what it can do.
Regards, Philip
Edited by smudge: 18/01/2011 - 17:42
royd63uk
Posted 18/01/2011 - 17:46 Link
Philip
please mark Jons post as helpful,its a great tip
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
layingback
Posted 18/01/2011 - 22:51 Link
GIMP has the Darla PurpleFringe script. Both free.
fatspider
Posted 18/01/2011 - 22:54 Link
If you live to 100 you'll still be scratching the surface and finding new ways to do this that or the other (in photoshop that is)
My PPG link
My Flckr link
