PTTR
Posted 14/04/2013 - 23:15
ETTR (PTTR) was introduced as a method of maximising dynamic range of early Digital sensors.
There's no need for it these days IMO. In contrasty scenes I always underexpose to try and avoid clipping. Cameras like the K-5 have great dynamic range to allow aplifying the shadows.
This is only going to get better in the future has sensor dynamic ranges increase
Posted 14/04/2013 - 23:43
In photography we have always been dependent on post processing to get the best out of an image.
In the days of black and white, enlargers sold in their thousands and home darkrooms were quite commonplace. So much so that as far back as the 1910s some local councils considered introducing water taxes on home darkrooms.
I had my own darkroom from about 1969 to about 1998, when it finally gave way to digital imaging. Now I do in Photoshop what I did in the darkroom, it all amounts to the same thing.
Posted 15/04/2013 - 13:08
There's no need for it these days IMO. .
Can we agree on 'there's usually no need for it' ?ETTR (PTTR) was introduced as a method of maximising dynamic range of early Digital sensors.
That isn't really in conflict with ETTR. Even with ETTR you would underexpose sufficiently to avoid clipping, overexposure would only be done when there was no clipping and available unused headroom.In contrasty scenes I always underexpose to try and avoid clipping.
Yes. But we don't all have a K5. And even with a K5 we have members here feeling it necessary to use an HDR exposure stack which tells me the camera's dynamic range still isn't (always) enough.Cameras like the K-5 have great dynamic range to allow aplifying the shadows.
Yes. But, ironically, as our camera's dynamic range increases further we will have even more opportunity for using ETTR to optimise results.
Posted 15/04/2013 - 13:19
This is usually done to make a pictorial effect, an aesthetic choice, rather than a technical choice.
Posted 15/04/2013 - 13:43
I agree with that.
When we all shot film we would expose for the highlights (ettl) when using transparency film and expose for the shadows (ettr) when using negative film. Digital is like shooting transparencies.
ETTR is fraught with danger and as Smeggypants says, unnecessary.
I don't think we are being pushed towards a reliance on post processing any more than film where developer choice and method as well as paper would have similar results
Posted 15/04/2013 - 15:35
johnriley wrote:
I wouldn't argue with that. But to turn the viewpoint around, if HDR isn't necessary to obtain an increased dynamic range it isn't necessary at all as we could get an identical effect by tone mapping within a single image.Quote:
This is usually done to make a pictorial effect, an aesthetic choice, rather than a technical choice.And even with a K5 we have members here feeling it necessary to use an HDR exposure stack which tells me the camera's dynamic range still isn't (always) enough.
And I do note your use of the word 'usually' John. Not always, like that nice Cathedral shot you posted earlier?
Posted 15/04/2013 - 15:55
Partially a fair cop, but that was HDR not because of an inherent shortcoming in digital cameras but because the dynamic range was impossible for any medium. Digital probably would have done better than anything else as there's not a film in existence that would have covered that one.Not always, like that nice Cathedral shot you posted earlier?
I would have shot several shots at different exposures and then combined the negatives - in effect, HDR.
Like I've suggested elsewhere...is this also the 'unforeseen' legacy of what is slowly and inexorably becoming a totally computer dependent world?
