PSE & Lightroom
Posted 05/04/2013 - 12:50
Do you tag lots of images with key words?
Do you need to quickly select candidate images from a large photoshoot then batch process them?
Do you need to organize high volumes of images into collections?
Do you mainly perform basic editing of single layer images?
yesses might point to LR being beneficial.
If you are low volume, if you are happy editing in PSE, if you can manage your image collections without LR then don't bother. Picasa probably will do for free.
Lightroom is as it says a kind of negative management environment with a basic (but highly effective) editor.
PSE is a cut down affordable consumer image editor.
Lurking is shirking.!
Posted 05/04/2013 - 13:15
Thanks for the reply
it sounds like I just stick with PSE really!
cheers
cheers
Posted 05/04/2013 - 13:57
I think "basic" is rather unwittingly dumbing down the power of lightoom's editing. Do you tag lots of images with key words?
Of course it doesn't contain all the features that you'd expect to cater for graphic designers/image editors, but for photogrpahers I'd hardly call it basic.
Posted 05/04/2013 - 14:06
Not unsophisicated, just basic.
Posted 05/04/2013 - 14:15
Basic it may be but in my very limited experience does appear to give many more possibilities with the RAW file?
Posted 05/04/2013 - 14:35
LR you can work on the RAW file in real time until you are happy with your view and export it.Basic it may be but in my very limited experience does appear to give many more possibilities with the RAW file?
PSE and PS you import the RAW file as a fixed starting point. You then edit from that fixed point. It requires more vision, perhaps, if you want to get to get to a particular point or just patience to perform the iterations of RAW import to get to your goal.
Back to basic: example
To invert an B&W image in PS, CTRL-I
To invert in LR3, muck about with the curve and drag the ends to the other side ..... I think.
Posted 05/04/2013 - 14:40
If you have only recently bought PSE 9 then I would spend more time learning to use it, and finding it's limitations before considering another program.
That said Lightroom and PSE do work well together, and you may feel you want to add it later.
Posted 05/04/2013 - 15:09
Hi Dave I have used lightroom from no1. I find it easer to use and find that it meets all my needs and very rarely use photoshop.
Derek
Derek
Posted 05/04/2013 - 20:10
Indeed. See the bit n bold.
Smeggypants wrote:
Of course it doesn't contain all the features that you'd expect to cater for graphic designers/image editors, but for photographers I'd hardly call it basic.
Posted 05/04/2013 - 22:31
I'm with Gwyn here -Lightroom and Elements do work well together -I do most things in Lightroom - however you can open up images in Elements from Lightroom when you need to do a panorama or use layers etc.
Posted 05/04/2013 - 22:34
Indeed. See the bit n bold. [/quote]See the bit in bold !!!
In comparison to PSE and CS5 it is "basic".Smeggypants wrote:
[quote:3496ace15f="dougf8"]Do you tag lots of images with key words?
I think "basic" is rather unwittingly dumbing down the power of lightoom's editing. [quote:3496ace15f="dougf8"]Do you tag lots of images with key words?
Posted 05/04/2013 - 23:57
dougf8 wrote:
[heavy Mancunian accent]No neeeeeeeeeeeeeeeed!!
[/heavy Mancunian accent]
Posted 06/04/2013 - 20:21
Davea66 wrote:
Hi
A little advice please!
I have a copy of Photoshop Elements 9 which seems to do everything I need.
I have been trying out the trial of Lightroom 4, which seems great at manipulating RAW files.
I have updated my PSE 9 recently to cope with Pentax PEF Raw files which seesm to do a lot opf what LR4 will do, although I like the publish to Flickr, Facebook etc. built into LR4.
So the question is really, if I have PSE9, do I really need to buy LR4 as well, or could I make better use of PSE9?
hope my ramblings make some sense!
cheers!
Dave
Since you already have PSE 9 you don't need to spend money on a RAW developer since one came FREE with the camera ! Hopefully you got Pentax Digital Camera Utilty (PDCU4) unless you have a K30 !Hi
cheers!
Dave
I use PDCU4 all the time now after I learnt how to use if from Nigel's 'Mini Guide' published elsewhere on this Forum.
I always shoot in both RAW and jpeg so that I can get a quick glance from the jpeg but use the RAW file for the images that I like. Whilst the 'out of camera' jpegs are not bad from the K-r they are often a bit dull and 'flat'. That's why I started experimenting with the RAW files.
PDCU4 is rather 'mind bogling' at first glance as it is not very User Friendly. However after spending a little time exploring how it functions with the aid of the Mini Guide it now only takes a few seconds to turn a dull image into one that 'sparkles' ! (At least, that's MY opinion !)
Good luck
Posted 06/04/2013 - 21:31
Having used PSE, PS5 & LR4 I would pick LR4 for photos every time for RAW. You do need to revert to PS for graphics and removing dust and objects as LR has a basic editor for those functions. If you shoot JPEG then PSE is a great option and also enables you to add graphic and text. PS is great for the ultimate in image manipulation but is not good for cataloging as Bridge is in my view quite basic.
K30, K-x, *ist DL. Pentax 60-250 F4, Sigma 18-125 & 70-300
13 years
Devon
cheers!
Dave
