Problems with Sigma 24mm Superwide lens
bigdaddybucks
Posted 17/09/2015 - 17:12 Link
Hi, seem to be getting a few problems lately, turns out my focusing issue with my K5 was more down to user error than camera error but now I have a different problem.
I have a manual focus Sigma 24mm f2.8 lens and for some reason the when I change the aperture on the camera it will not go down past f4 it will go up to 22 but not past f4. The lens is definitely set to the "A" setting and I have tried another lens that goes down to f3.5 no problem. Any ideas anybody?
Thanks in advance
Lee
Algernon
Posted 17/09/2015 - 17:28 Link
Sounds like the contacts..... Try cleaning them. Waggle the lens about a bit when fitting it.
Top lens.
bigdaddybucks
Posted 17/09/2015 - 17:52 Link
I've tried waggling contacts look clean.
Algernon
Posted 17/09/2015 - 18:21 Link
Is the set to Manual metering? It should be.
Are you using LV, because LV closes the aperture down automatically if the scene is too bright.
Algernon
Posted 17/09/2015 - 18:32 Link
Hmmm! I've got 2 of these and I just tried one on a K-5. It was already set to 'A' and the aperture only worked from f/4 to f/32. I pressed the green button to take a meter reading at f/4 and then set the lens off 'A' and at f/4 manually. Slight difference in readings could even be a stop.
Without touching anything else I set the lens to 'A' again. This time it went down to f/2.8 so maybe you have to set 'A' on the camera with it switched on.
bigdaddybucks
Posted 17/09/2015 - 18:39 Link
It's very strange, pretty sure i have used one of these on my K5 before with no problems.
StephenHampshire
Posted 17/09/2015 - 19:42 Link
I used to have the manual focus "A" version and now have the AF version, both work(ed) fine down to f2.8 on my K5. Normally the problem is dirty contacts on the lens (or occasionally body) Give them a clean with a lens cloth and see if that helps.
bforbes
Posted 17/09/2015 - 19:54 Link
Mine also works well on a K5-lls
bigdaddybucks
Posted 17/09/2015 - 20:01 Link
It worked fine yesterday for a few hours I have checked the first photos I took and they are definitely at f2.8, all the contacts are spotless, tried all kinds of things and it still won't go below f4.
