Printers - Urgent help and advice!
polchraine
Posted 29/01/2009 - 06:55 Link
It has to be your browser setups ...
[IMG]http://i2.photobucket.com/albums/y31/Polchraine/PentaxForum/PU_290109.jpg[/IMG]
I can see nothing wrong.
shim
Posted 29/01/2009 - 08:24 Link
polchraine wrote:
Shim, which browser do you use - it is probably a failure of that to interpret the data correctly. To me it is fine and just 16 characters wide on 3 lines.
Firefox and it's 35 chars on one line with no spaces. John Riley and another poster have both mentioned it, so it's not just me, after ZRH or your 19th char. your overwriting the "body text" with 16 chars.
shim
polchraine
Posted 29/01/2009 - 09:11 Link
Shim,
That is down to your browser set up and the fact that it is not sorting out "Word Wrapping" correctly.
The image I have posted about shows that Firefox when set up appropriately interprets it correctly.
iceblinker
Posted 29/01/2009 - 09:50 Link
It's all on one line for me in IE too.
It'll be nice if you could modify it so it appears OK on the majority of people's browsers the way they have them setup, raher than your browser with the way you have it setup.
~Pete
shim
Posted 29/01/2009 - 11:54 Link
polchraine wrote:
Shim,
It is "Word Wrapping" correctly. You've put your location down as a 35 char. long word, so it should appear on one line. If you left a couple of spaces it would "Word Wrap". I don't know why you can't just put down your hometown or county like everyone else does.
Pentaxian450's is wrapping correctly? probably because he's used spaces and commas.... It must be something to do with it being you own post that it gets sent differently.
shim
Edited by shim: 29/01/2009 - 12:01
Anvh
Posted 29/01/2009 - 13:20 Link
I also have no problems, maybe we should make a poll out of this
Andrew, just add some spaces into it so that we can end this useless topic
Stefan
K10D, K5
AF-540FGZ
loskeran
Posted 29/01/2009 - 13:45 Link
Anvh wrote:
If you were happy with Epson this might be a good option Epson R800
Or else Canon ip4500 or ip4600 would be good enough maybe, it really depends on what you want and for what price?
Since you said Her business use is the primary function it makes it quite hard to know what you expect from it, at least for me.
The models I name come both with 2 kind of black inkt, one for photo and one for texts.
Hi, my input would not be the R800 I had one, it was a nightmare even on genuine inks,that bad i binned it, i now use the R1400 A3 also a photo 285 A4 6 inks at reasonable price, it does my general printing and does very good photos,also i have never had to clean the heads on either, the newer Epsons seem to have overcome the old problem they suffered.
screwdriver
Posted 30/01/2009 - 00:30 Link
My answer to this question a few years ago was to buy a Samsung laser printer for all my text documents, much faster than inkjet, the prints are waterproof (well the paper isn't, but the text is). Dirt cheap to run I just refill the cartridge with toner (thats why I bought a Samsung) and I'm good for another 2500 A4 sides.
I also use it to make printed circuit boards.
My photos are printed on an Epson R1800, pretty old now but still going strong.
Chris
wasleys
Posted 30/01/2009 - 01:11 Link
Problem seen in Firefox, Camino, Safari and SeaMonkey.
Argee
Posted 30/01/2009 - 09:10 Link
Have a look at an Epson Stylus PHOTO R265 (or updated model). Unbeatable value and very good photographic printing, especially borderless, prints on suitable CDs too. Uses Claria inks (6 colours).
Ray.
Z1, K10D, D-BG2 Grip, DA 1:3.5-5.6 18-55mm AL, DA 1:3.5-6.3 18-250mm ED AL(IF), AF540FGZ Flash, FA 1:1.7 50mm, DA 1:2.4 70mm Limited, Wireless Remote (Did I offend you? Click here).
aminstar
Posted 30/01/2009 - 09:43 Link
I use firefox and it seems fine. But on IE it definitely shows all crossing the comments window.
Is your firefox version the latest?
Amin
shim
Posted 30/01/2009 - 09:59 Link
Comet are giving 10% off on multifunctional printers online.
Some stores may have the iP4500 for £48. I bought one yesterday, I already have an A3 and A4 printer, but £48 is only about the cost of the inks so I bought it.
shim
