Print quality - or lack of.
Posted 08/04/2011 - 22:19
The difference in images your describing is down to the way your viewing them. The pc image is backlite and the print is by reflected light. An image on the PC always looks better than a print. Ways to ensure they look the same are to calibrate the printer with your photo paper and ink. Are you using the printers recommended paper? your printer will carry the profiles for this paper. I dont do much printing, but you can set photoshop to mange printer profiles or let the printer manage profiles. I let the printer manage profiles.
Posted 08/04/2011 - 22:28
As I recall PSE does not allow ICC profiles in the same way full Photoshop does. I'm away from home now so can't look it up to tell you how to do it but you have to allow either the printer or PSE to manage printing. If both are trying to do so you will have problems. Of course you can look in PSE Help for how to do it.
Posted 09/04/2011 - 00:58
Knowing what printer(s) you're using would also help. Different makes have different characteristics. Knowing what printer(s) you have could get you more help from people having the same brand/model.
Posted 09/04/2011 - 22:04
Thank you all for your info, I see the direction in which I must go and it obviously requires a bit of reading!
Gwyn, yes if I understand correctly, PSE9 only allows one to imbed a tag to the printer manufacturer's Icc profile - my next move now obvious!
(Unless I splash out on PS proper that is, although having just bought a Sigma 105 macro that might not go down too well :roll
Yves, Canon Pixma iP4500 (3 colour + blacks) and Epson Stylus Photo (5 colour + black. The Canon print colours tend to be more natural than the rather vivid (technicolour?) results obtained from the Epson.
Surrey
Obviously the camera is not at fault (it produces the aforesaid masterpieces), and both printers are capable of producing reasonable prints(mostly those taken by my wife. :blush
Any attempt at 'lightening' the screen image tends to destroy highlight detail in the prints, although the fill light feature seems to be the least destructive.
So, I am wondering if there is a breakdown in communications between my imaging software (PE9) and the printers. I am sure that I have read that some, or perhaps a particular, imaging software can directly set up and run a printer to suit the individual pictures being processed.
Once again your advice would be greatly appreciated.
Roger
