preparing for patagonia
Posted 28/01/2013 - 14:24
Monopod only your only taking light kit.....
if you had a sigma 100-300 f4 or 50-500mm i would take the tripod..
Posted 28/01/2013 - 17:48
interesting point. unfortunately the reason for not taking the tripod is the weight
Posted 28/01/2013 - 17:49
Whilst the tripod would be a heavy bit of kit to drag around - without it you are bound to find situation when you would have welcomed the support.
May be worth considering something like a gorillapod SLR Zoom with the ball head on it. Small, cheap and very light and in my experience - very useful!
Carl
Carl
Posted 28/01/2013 - 18:38
Are you likely to shoot nighttime skies, moonlit landscapes, landscapes after sunset or before sunrise? Or use a 10 stop ND grad to blur moving water, clouds or vegetation? Or do you want to squeeze every last pixel of sharpness out of your lenses for that A2 enlargement you know you'll need? If so, that Manfrotto 190 will suddenly become indispensible, 'cos you can't do that with a monopod! If no, then leave it or go for one of the lighter options.
Good luck, seems like an awesome place to visit, look forward to seeing the images!
Paul
Paul
K3ii, DA16-85, DA35mm Limited, FA77mm Limited, 55mm f1.8 K, 135mm f3.5 M, DA300, DA 1.4 HD TC,
DA16-45, Sigma 15mm f2.8. Cosina 100mm f3.5 macro
Posted 29/01/2013 - 00:27
I find a tripod invaluable for travel and it only weighs 1.5kg. Without it I'd have far fewer night shots and far fewer shots of my wife and I together. The tripod is the third member of our family when travelling.
