Pre-focusing and shutter locking on *istDS
Use a manual focus lens, but set the camera on AF
Focus on the place you want.
Press and hold the shutter release - when something appears at the pre-focused spot the shutter should release.
The adaption is quite easy following Matts instructions on using a 2.5mm phono plug.
David Benson
(on remote shutter release)
You could try the following:
metering has to be in manual and set beforehand, so there could be some considerable light change/ exposure level by the time the piccy is taken
Andy
21 years
