power zoom broken switch
chrissinkpen
Posted 11/08/2011 - 17:41 Link
I know this is a very common problem with the power zooms. I recently acquired one with a body that I bought, the lens is in brand new condition. Does anyone know whether these switches can be repaired please.
thanks.
Chris
Posted 11/08/2011 - 18:03 Link
Asahi Photo was the last place I used.
Dangermouse
Posted 12/08/2011 - 22:53 Link
You can fix them yourself if you have all the parts.
Just put it all back together and hold the cover in place with a thumbnail while checking that the switch and button both work as they should. Next, lift the cover and put a tiny drop of superglue on the clip intended to hold it onto the lens barrel, then press it back into place. Use the smallest drop you can - you can always go back if it doesn't stick, but using too much risks gluing the lens solid or fogging elements/plastic trim as the glue hardens. Mine was repaired this way, seems to work perfectly and the repair is invisible.
Edited by Dangermouse: 12/08/2011 - 22:54
chrissinkpen
Posted 13/08/2011 - 00:20 Link
Thanks Matt for the advice.
When you refer to "the clip" I presume that you are referring to the tiny little bit of plastic that seems to break off very easily on the clip.
regards
Chris
Dangermouse
Posted 13/08/2011 - 08:15 Link
Yep - I mean the bit which projects from the cover plate and clips into the slot in the lens. There's one at both ends but mine holds fine with glue on only one end, which reduced the risk of making a mess of it. Generally one clip is broken anyway, this is why the switch falls off!
