Power supply for *ist-D
Posted 27/01/2005 - 04:36
Great! If it's ok let us know if it would fit the Ds as well. I don't fancy paying almost £50 for the Pentax version.
I've had good experiences of 7dayshop where you bought it since I read about them on this forum.
Posted 09/02/2005 - 05:03
Mat,
did the power pack work ok ?
Bryan
Bryan
Posted 09/02/2005 - 06:31
Bryan,
I bought both supplies (there's a 1Amp and a 2.5Amp, each with different voltage ranges). Both are really neat and compact. I haven't had a chance to use it on the *ist-D - I did use the 2.5A on the Flashtrax which worked a treat.
I'll try the *ist-D tonight if I get a chance
Posted 11/02/2005 - 03:24
Just for your information...
I couldn't get the power supply working on the *ist-D - the plug sizes don't seem to fit well enough . I'll see if I can come across an alternative.
Posted 11/02/2005 - 05:30
Hi Matt,
Thanks for letting us know
Bryan
Bryan
Posted 11/02/2005 - 07:44
Correction
It does work. There are two yellow tipped plugs - the larger of the two fits, but you must push it home properly. Also, make sure that the Tip sign on the lead matches up with the + sign of the plug.
The thing that caught me out: I was trying it with the battery compartment door open to prove that I had no battery power. The *ist-D has a door sensor and won't power up if the door is open! So you can use the power supply if the door is closed!!
Posted 11/02/2005 - 13:16
Hi Matt,
Thanks for post.
Am a bit confused, which one is for the *1st d ( you say you bought two ) and voltage please ?
Bryan
Thanks for post.
Bryan
Posted 12/02/2005 - 10:15
Bryan - you need the "digital" one. It's 2.5A, and has selectable voltage. You'll notice the voltage you need is marked on the camera - 6.5v (So you set the switch before plugging in )
Posted 12/02/2005 - 12:27
Hi Matt,
Do you know I looked right thro the manual and on the net for the voltage
and all the time its on the darn case
Ta
Bryan
Ta
Bryan
Posted 22/02/2005 - 13:48
Hi Matt,
Got my power kit today, works a treat.
Thanks for tip
Bryan
Thanks for tip
Bryan
24 years
Sussex,
UK
I've just ordered a supply for my *ist-D:
http://www.7dayshop.com/catalog/product_info.php?products_id=8158
(A good idea when doing CCD cleaning etc).
I'll let you know how it fairs when I get it
