Post-Capture Image Adjustments in Recording Mode
Posted 07/03/2015 - 19:38
Very interesting, Nigel, I'd read of this facility on my K5, but have never used it.
I could never imagine standing around on a beach of hill, trying to, in effect, post process an image on a tiny screen, but others might find it useful. I've been fiddling about with the JPEG settings on a camera I bought recently although I generally rely on RAW development in comfort of my own home.
Thank you for taking the trouble to explain.
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 07/03/2015 - 20:03
I think there are certainly times when any very specific custom adjustments will not be practical, when you have to shoot quickly or when the lighting prevents you seeing properly on the camera screen.
A good practice would be , I guess, if you know the conditions and style of photography you're going to be shooting, to try and get the main settings right before you head out, and just make minor adjustments if needed in the field.
This is where the Post Capture JPEG adjustments could help, when the lighting has changed and you hadn't anticipated it before shooting, or your lighting balance looks wrong.
My attitude to camera JPEGs is that if you're going to use them, then its best to get the camera to process them as accurately to the final output you want as possible .... this is because only the camera has access to the actual original full depth image data, and so the camera processing can give the best initial high quality . if we leave things to be changed later on a computer, we've already jumped down to an 8bit file ....
So for JPEG capture I see the camera image settings as very important to get right on the camera.
Posted 08/03/2015 - 18:34
I looked into something similar at he weekend. I was looking to turn my camera into a girls camera for my daughter. Setting the menu mode to colours #4 made all the rear lcd screen boxes pink, which got the tick of approval.
I tried the toy camera setting but all shots had to be blurred so I moved off that. I wasn't able to apply the art filters to RAW files though. Maybe id need to spend more time playing in there, or just buy a compact.
Posted 09/03/2015 - 17:08
A girls camera!?! Vtech make those I think. Actually, I like to sometimes change my display colours for variety ... Makes you look at the control items with fresh eyes I find, so actually quite a worthwhile thing to do, but I've never liked the orangy / pinkish option ... Generally I go for the two-toned blue or grey ones ..... Definitely a boys camera for me!
The way the digital preview memory image can be used in these different ways is very practical I find ...I assume that most people, like me, now choose digital preview over the alternative of depth of field preview (both activated with a right turn on the on/off switch ??) It really is a great way of assessing the effect of our camera image control settings and seeing the alternatives. And of course to have the memory file from the last shot there ready to be edited in another way is very handy ... Although I guess the extended bracketing function, if you identity the need in advance, will save time.
It's worth pointing out that extended bracketing does not actually take 3 separate frames, so no need to use a tripod our be very steady, but rather it just applies the alternative processing to the additional jpegs.
Posted 09/03/2015 - 18:20
McGregNi wrote:
But what options do we have if we forget to change one of these critical settings before taking the shot?
Nigel, thank you for that interesting information. However, if a JPEG was accidentally recorded with the wrong settings, and/or the result looks a bit problematic on the rear LCD screen and histogram, and it is not possible to re-take that shot, that is one of those few occasions when I would just press the AE-L button when in the preview to record the Raw file, and adjust it in ACR later.But what options do we have if we forget to change one of these critical settings before taking the shot?
Cheers.
Philip
Posted 09/03/2015 - 19:00
That's another useful option, thanks Philip ... Personally I've always had much greater success with White Balance control using the camera settings, rather than any post-processing .... And you might be surprised to hear me say that I find that for RAW as well!
Even with RAW capture, the camera white balance controls are effectively a colour temperature number recorder, and the file metadata will pass this number over to the RAW converter to be automatically applied via the default ' as shot' WB preset. I find the advantage of fine tuning white balance oh the camera screen right in front of the actual scene is greater than any sophisticated software controls.
So for white balance I'd always aim to get it as accurate as possible in camera ... But for the other custom settings that our AE-L button can save in record mode, then yes, for those using RAW software they might prefer to make those adjustments on the computer . For joeg shooters nothing beats good accurate camera custom settings, and if you can't reshoot the scene then this method provides a great extra choice!
Posted 09/03/2015 - 20:54
Yeah my eldest (6, soon to be 7 years old) has a natural eye for photography. Her hands are now big enough to hold the DSLR.
Posted 09/03/2015 - 21:03
No, my workflow is quite different. I don't use the digital preview at all, opting instead to take an actual shot and review it. I find I have fast and large memory cards, which are quite cheap these days, so I don't mind shooting actual test shots and these are saved as JPG and RAW in most cases, with only the RAW being imported into Lightroom for processing. I assume that most people, like me, now choose digital preview over the alternative of depth of field preview (both activated with a right turn on the on/off switch ??)
The camera white balance is completely irrelevant for RAW use for me, other than it is used as a starting point when the RAW file is loaded. A single click with the white eye dropper tool and it's in the ball park instantly.
I use the optical preview when I have a manual focus lens attached, as I find it very difficult to nail the focus through the still relatively small optical viewfinder otherwise, - given the normal display aperture is not set to what it will be when the shot is actually taken. Live view gets around this and offers the focussing aids of focus peaking and digital zoom, but the stance isn't as supported this way, which is where a decent EVF would be the best option.
By the way, Pentax haven't kept the preview button on the on/off switch for all models, and the K-S2 has a movie mode set there. I remap the side RAW/FX button I think it is to optical preview.
Posted 09/03/2015 - 21:34
richandfleur wrote:
Well I just keep the battery grip firmly welded to the K7 .. That stops my 7 year having it quite effectively!
Yeah my eldest (6, soon to be 7 years old) has a natural eye for photography. Her hands are now big enough to hold the DSLR.A girls camera!?! Vtech make those I think. Actually, I like to sometimes change my display colours for variety ... Makes you look at the control items with fresh eyes I find, so actually quite a worthwhile thing to do, but I've never liked the orangy / pinkish option ... Generally I go for the two-toned blue or grey ones ..... Definitely a boys camera for me!
Posted 09/03/2015 - 22:34
lol, no I'm the other way, I want her to learn to use it Well I just keep the battery grip firmly welded to the K7 .. That stops my 7 year having it quite effectively!
Maybe a Q would be better suited though. I can't see kids growing up with optical viewfinders for very much longer. Even now most 'cameras' young people use don't have any view finders at all.
Pink menu's are as far as I'm prepared to go.
Definitely not this:
Posted 09/03/2015 - 23:49
Hmmm, I don't know ..... I guess so long as it had a full range of customisable options for saving variations on the last shot jpeg, plus a complete set of extended bracketing custom variables .... then I'd be quite happy with it !
Surrey,
England
Now of course, if shooting JPEGs, the optimum approach would be to tailor the custom settings to each scenario or photographic style, and change the settings regularly as the image needed. But this is not always practical .... its basically doing your image editing during the shoot. But some critical aspects of JPEG editing are important to get as right as possible in the camera .... I’d argue for White Balance, saturation and some contrast control as being important to record as early in the processing chain as possible. But what options do we have if we forget to change one of these critical settings before taking the shot?
Our K7 & and K5 models provide a handy ‘plan B’ (I’d ask users of any other bodies to check and post here if other models offer the same feature) ..... this is an option to Modify JPEGs in Capture Mode.
Normally, post capture image processing on our DSLRs is carried out in the Playback mode, where we can select RAW images for development into TIFF or JPEG files and apply the full range of camera settings. This can be carried out at any time to any RAW file on the SD card. New output TIFFs or JPEGs are saved as new images onto the card.
But this won’t help if we’ve already shot a JPEG. Here’s where this handy function comes into its own ... it takes advantage of the fact that the last recorded image remains in the camera memory even after writing to JPEG has occurred, and stays there until a new shot is taken or the camera is switched off. This last shot in memory is usually used to provide the ‘Digital Preview’ image on the LCD that is handy for tweaking settings and checking the effects.
However, using this memory image we can actually create a brand new JPEG output with some different settings even after the original shot was recorded ... we are effectively making the camera ‘re-process’ the file again with our new chosen improved settings. We can make the full range of adjustments to both the White Balance and Custom Image Settings.
Here’s how its done ....
- After taking the image and deciding you want to make adjustments, be sure not to take another shot, nor switch off the camera
- Press the 4-way controller’s left key for White Balance
- Make any WB changes to the preset and fine tuning controls but ...
- Do NOT press OK
- Instead, press the AE-L button, and the camera will ask to save the new file ....
- Press OK
- Now you can continue by pressing the right 4-way controller button for Custom Image Settings
- Make any Custom Image adjustments required but ...
- Do NOT press OK
- Instead, press AE-L, and the camera will ask to save the file ...
- Press OK
You’ll now have two additional JPEGs, one with the White Balance changes and the other with both the White Balance and Custom Image Settings changes.
Its a great option to get it right in camera if you shooting quickly and didn’t have time, or you forgot and had the wrong settings. Another amazing feature of our Pentax DSLRs that help us get the image right ..... Why not give it a try !
Nigel McGregor
