Polarizing Filter vs Natural Density
Posted 27/04/2009 - 13:15
I do it all the time. (fall shots with my varicolor polarizers and regular polarizers....and sometimes with two regular polarizers for fun)
two catches:
A) cheap polarizers (one should be linear instead of circular) can cause a dramatic and sometimes uneven color cast (usually purple).
B) two layers of glass = two times the number of surfaces between your lens and your subject... twice the chances of dust, flare, and image quality loss etc...
so buy good filters and really get the graduated nd's at least...
two catches:
Posted 27/04/2009 - 13:35
Mannesty wrote:
I think you mean neutral density. Using 2 polarizers in this way will cost you about 2 f-stops, if not more.
What exactly is the point? Why not just underexpose if you want to lower the overall brightness of the scene?
shallower dof and or slower shutterspeeds....I think you mean neutral density. Using 2 polarizers in this way will cost you about 2 f-stops, if not more.
I often need both a polarizer and a ndgrad for outdoor portraits...
ie getting shallower dof and a slow enough shutter speed for flash in a park setting...
Posted 27/04/2009 - 13:53
Thanks Don.
Posted 27/04/2009 - 13:56
U R Welcome!
another good use for two polarizers is to put one on your flash and the other on your lens...
then you can "Dial out" glare off reflective surfaces (not chrome or mirrors) or oily skin and esp dark colored skin.
Leuven Belgium
Has anyone ever tried these combo of 2 Polarizing Filter together?
K20D, *istDL, MZ5, MX and MV
Leuven Belgium
