polariser
davem
Posted 29/09/2011 - 19:56 Link
Is here any reason why a circular polariser lens would not work with the non digital lenses and a film camera?
Dave
davex
Posted 29/09/2011 - 20:59 Link
No,
Also, Polarisers come in two forms, Linear and circular; this refers to the type of Polarisation not the shape of filter.
Most AF cameras cannot use Linear Polarisers due to the effect the polarisation has on the AF detector, this does not apply to Pentax AF systems
Linear polarisers are much cheaper than circular polarisers, if you can find one.
The only issue you may have is seeing the effect in the viewfinder, much more obvious using live view.
Davex.
My flickr: link
ChrisPlatt
Posted 03/10/2011 - 20:27 Link
Whenever possible I prefer to use linear polarizers for their more pronounced effect.
A linear polarizer will cause erroneous readings on a Pentax LX in manual mode.
Chris
Bring back the latent image!
Hardgravity
Posted 03/10/2011 - 22:43 Link
When I shot a lot more film than I do now I used a linear polarizer on my lens.
By turning the filter whilst looking through the viewfinder you could see the effect.
I don't think circular ones show this, which could make them awkward to use.
Cheers, HG
PPG entries.
davidstorm
Posted 03/10/2011 - 23:24 Link
The circular ones do allow you to see the effect when rotated. However, beware using a circular one on the DA 55-300 lens as it upsets the optical configuration of this lens and causes shots to be very out of focus.
Opethian
Posted 04/10/2011 - 01:06 Link
Okay, this is contrary to what I read almost everywhere on the web. Are you saying my GX-10 can use a Linear Polarizer?
gartmore
Posted 04/10/2011 - 07:35 Link
Chris
Well done! I thought I was the only person around here who knew that
Linear PLs work perfectly well on Pentax cameras.
Pentaxophile
Posted 04/10/2011 - 08:21 Link
I never believed the 'linear polarizers don't work on digital' line, and have been using them all along with no problems. Even if they did cause AF and metering issues, it wouldn't matter for what I use them for, as there's plenty of time for manual adjustments in landscape photography.
womble
Posted 04/10/2011 - 13:04 Link
Chris
I'm curious as to what the problem with the LX in manual mode is? Largely because I am a LX user that often uses a polariser, although I think all mine are circular. I often wondered if circular ones were less effective as I remember how much difference the linear one made with my ME Super back in the day.
Thanks, Kris.
gartmore
Posted 04/10/2011 - 13:18 Link
Kris, somewhere I have the Pentax CPL instruction leaflet which explains the problem, I'll have a hunt for it.
womble
Posted 04/10/2011 - 14:28 Link
Thanks Ken.
Kris.
gregmoll
Posted 04/10/2011 - 17:26 Link
Here is a link to the Pentax filter manual.
link
Greg
davem
Posted 04/10/2011 - 19:23 Link
thanks for the help
