Pochard
Posted 21/01/2011 - 09:45
I think I would be tempted to lighten the shadows a touch Roger. Very nice image.
Gear Not enough!!
My not so new website
Gear Not enough!!
Posted 21/01/2011 - 12:07
Mannesty wrote:
...and unfortunately, your subject is not sharp...
Possibly due to 300mm at 1/200th hand held. Not impossible, but a bit of a challenge.
Posted 21/01/2011 - 13:23
I think it's reasonably sharp, but could be better. The beak looks okay, but the eye doesn't. This is wide open at 300mm, perhaps stop down a bit if possible (what was the ISO?).
Tim
Posted 21/01/2011 - 13:57
I think that there are several factors influencing the lack of sharpness in this image.
1: The shutter speed is too slow at 1/200th for a 300mm lens.
2: The aperture is too wide making any available DOF very small.
3: The available light didn't allow the use of more appropriate figures for 1 & 2 above and excessively high ISO (though we don't yet know what was used) on the K7 introduces noise.
4: The eyes are not in the plane of focus.
5: The image is cropped, perhaps a bit too much.
Posted 21/01/2011 - 14:31
Thanks for all comments, folks.
ISO was 400.
Crop is about 40% of the original.
As ever(?), it was a case of needs must: the light was what it was, I only have the 55-300,the level of crop is necessary to get a reasonable size (of bird) onto an A4 print.
....But apart from that, everything's fine!
I'll keep trying!
Roger.
ISO was 400.
I'll keep trying!
Roger.
Posted 21/01/2011 - 15:08
I've taken the liberty of playing around with it Roger, see what you think. I always set my shutter speed at around 1/320 when shooting at the long end of my 55-300. Unfortunately or fortunately depending on the situation, shooting with a zoom at them long end means a reduced DOF. If you are using shutter priority for moving wildlife/birds I always find upping the ISO is necessary for low light. Neat Image is a good noise reduction software which can be used in PSE.
[IMG]http://i1098.photobucket.com/albums/g370/jimbo_609/LangfordLakes025crop_filteredcropii1.jpg[/IMG]
Gear Not enough!!
Gear Not enough!!
Posted 21/01/2011 - 15:30
Thanks, Jim, & of course I don't mind!
That certainly is an improvement. I had put mine though Neat Image, using the"recommended" settings. Perhaps something a little stronger was required...
Roger.
Roger.
Wiltshire
K7, 55-300 @300, 1/200th sec. @f5.8, hand-held, manual focus,cropped & pp in PSE9.
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/LangfordLakes025crop_filteredcropii.jpg[/IMG]
Coker.
