PLEASE HELP - K5 Locked
Posted 03/04/2016 - 14:26 - Helpful Comment
The first place to start is with things you can do. Remove the battery, leave for a few minutes and then re-insert the battery. See if that clears the problem.
If there's a firmware upgrade on the Pentax website, then to that and see if that helps.
Also use a soft dry cloth to clean the electronic contacts on the lens and camera body, in case a lack of contact is causing the problem.
Finally try another battery in case the one you were using has developed a fault.
Finally, return the camera to get a quote for repair if still necessary.
Posted 03/04/2016 - 14:46
Thank you John,
I've already tried the battery, and the firmware is the most current. I shall try cleaning the contacts, and see if that helps.
Do you know if this is a common problem???
Also, I know about Johnsons, but is there somewhere else people recommend for repairs? I have found AsahiPhoto but know nothing about them.
Thanks again
Thanks again
Posted 03/04/2016 - 15:29 - Helpful Comment
If you join Pentax User Plus then you get 20% discount on service from Johnsons. You need to download the form from this site and send it with the equipment.
Posted 03/04/2016 - 15:53 - Helpful Comment
Had the same trouble, reset to factory settings ,and it seems okay now
Hope this works.
Stan J
Hope this works.
Stan J
Posted 03/04/2016 - 19:42 - Helpful Comment
had the same problem , did all the stuff that has been suggested here which appeared to cure but it kept coming back, usually when you least wanted it the shutter count was around 35-40,000 so got rid and bought a 11s. it is a fault that was reported more than just now and again but not a real hot topic like the AF problems with the model, somewhere in between. would not think repair would be a viable option financially when the camera is only worth the cost or even less maybe.
Posted 03/04/2016 - 22:09
Thanks guys.
I'll try a factory reset too. I figured it will not be financially viable to pay for repair. (Secret high fiving myself and counting up the coin pot). I checked and my shutter count is only 16k, but I think this must have been reset when I had the service done as I'm sure I have taken many more than this.
Posted 05/04/2016 - 21:48
UPDATE- I've tried all the suggestions bar sending it off for repair. She dead!
I'm thinking of putting all my pennies toward a k3ii, and maybe selling the k5 cheap cheap for parts??
Thanks for all the suggestions/ advice amigos!
Posted 05/04/2016 - 22:23 - Helpful Comment
If you only have the one battery it's definitely worth trying another.
My son has a battery that appears to charge, shows charged, but fails as soon as you try and do anything.
Posted 05/04/2016 - 22:43
Thanks Matt,
But I can do everything but take a photo, and the battery seems fine.
I might just pop into a shop and try one though to be sure!
11 years
I'm new to here. I was on holiday in Ljubljana a couple of weeks ago, hammering out travel snaps on my K5, when all of a sudden I couldn't take a photo. I was on auto, and zooming/focussing fine, but couldn't even depress the button halfway. Then received a message on the rear screen 'Battery Depleted'. I thought that was weird as the battery indicator had been on full, but just assumed I had worn it out that day. Got home, charged the battery - same problem. Changed lenses - same problem. I've only managed to find one topic on forums about a similar problem, but their problem was intermittent, and still cost around the £200 mark. I've never had a problem with it before and it gets lugged around when I travel, not to mention subjected to the elements! It was serviced and had the sensor cleaned by Johnsons about 2 years ago.
My issue is that I don't want to waste a penny on it if the repair is going to be more than £100, I'd rather invest in a new camera.
Has anyone else had this problem, or could anyone give me a ball park guess as to repair cost?
I'm kinda hoping it will be pricey so I can justify to my broke self to buy a K3 or K3ii (any opinions as to which is better???). The FF looks lush, but I cant afford it or the good glass, and for what I need, I think the k3/k3ii would suit me.
Thanks in advance
