PK fit lenses
Posted 07/10/2012 - 11:22 Link
Hi guys,
Can anyone tell me what other non pentax lenses are PK fit I think I read lenses for Chinon cameras are PK but what others?
Digital Equipment: Pentax Kr, Pentax SMC DAL 18 -55mm & 50-200mm Zoom Lens, Pentax k100d, SMC DA 18-55mm, Tamron 70-300mm LD Di 1:4-5.6 TELE-MACRO lens, Jessops 280D flashgun, Hama Star 63 tripod and Jessops monopod.
https://www.flickr.com/photos/scotia_photographic/
PeterKR
Posted 07/10/2012 - 12:11 Link
There is a wide choice of non-Pentax lenses available to fit your K-r and you will find a long list on the 3rd Part reviews on the US website at the link below:-
http://www.pentaxforums.com/userreviews/
Note that many lenses have an additional 'Ricoh Pin' which can cause problems on Pentax DSLR's, but that's another story and you'll find many postings about that on this site !
If you are happy with manual focus and manual aperture setting then you can also use old 42mm screw thread lenses with a PK adaptor ring. I use one with my old Helios 58mm f/2.0 lens and a Pentacon lens I got off ebay.
Best wishes
petrochemist
Posted 07/10/2012 - 18:01 Link
I think Peter overstates the Ricoh pin, I'd expect it to be far less than 10% that have it so 'some' rather than 'many'. It's fairly easy to remove but I guess important to check on.
As well as the M42 lenses, T2 mount & adaptall lenses can also be used with readily available adapters (many of the adaptall ones work with auto aperture if you get the PKA adapter.
Algernon
Posted 07/10/2012 - 18:16 Link
As long as the Ricoh pin is the rounded type it's not usually
a problem.
johnha
Posted 14/10/2012 - 23:54 Link
Loads of manufacturers made K or KA mounts, either as 'own brand' lenses or as 'independent' lens manufacturers. As stated most of the independent 'KA' lenses also included the Ricoh pin. I've used these lenses on and off for years on Pentax AF film bodies without any problems but when I bought my K-5 I removed all the Ricoh pins as per the instructions on this site: link. This was purely because the cost of the K-5 made this a sensible precaution (and because I found the site above and found it to be an easy procedure).
Note: Some of the independent lenses have a longer baffle around the aperture simulator lever which fouls the powerzoom/SDM power contacts (approx. 5 o'clock on the mount from the front) and prevents the lens from mounting.
The short list is:
Chinon, Cosina, Centon, Ricoh, Sigma, Tamron Adaptall, Tokina, Vivitar but I'm sure there are many more (I think Practika & Zenit even made K mount bodies?).
